TLR 22 Racing Buggy Thread
subscribed
Motor - It really depends on the class you are going to race in. For example, Orion make the best mod motors IMO. If you race stock, then opinions will vary widely, but I do not race stock and don't have a strong opinion in any direction.
ESC - Orion R10 Pro. It is easy to use, looks clean, but most importantly has the best "feel" of any ESC. When racing R/C, we don't have the benefit of a "seat of the pants" feel and thus the "feel" of the ESC is the most important attribue IMO. The LRP stuff was the best for a long time, a step above the rest, but now Orion has taken another leap forward with the R10.
Tires - This one really comes down to the exact track. Indoor clay will vary from track to track. I would ask one of the fast local drivers his suggestion, and it will likely put you on the right path.
Matt C./Frant R./Casper -
Considering purchasing a 22. What items are needed outside of the kit, which folks are running today?
From what I heard, the following are must have's:
3.0* rear toe block
5.0* front caster
Nice-to-have:
Low Friction o-rings
Threaded front king pin
Threaded rear hinge pin
Shock tool plastic (don't believe this comes with the kit)
Thx in advance!
3.0* rear toe block
5.0* front caster
Nice-to-have:
Thx in advance!
Must Have:
Shorty LiPos
3.0* Toe Block
5* Front Castor Blocks
Threaded Front King Pin
3.5* Toe Block (depends on track/driver)
Alum Servo Horn
Nice to have:
Low Friction O-Rings
Titanium Shock Mounts
Alum Rear Camber Brace
Alum Battery Brace
Alum Front Pivot
Alum Washer Set
Threaded Rear Hinge Pin
Titanium Turnbuckles
Alum Shock Tools (plastic ones do come in the kit)
I cant wait for my r10 pro! Im still running an lrp motor but think i will slowly switch to the orion motors.
I'm going to be buying a tlr 22 on amainhobbies.com and really needing some help on tire choice for a buggy. Track is packed and about 1/8 inch of loose dirt on top.. I want goosebumps on the back and just can't find what to get for the front. Would love to get it all from amain in one large order.. Thanks.!.
http://www.amainhobbies.com/product_...-Tires-Green-2
Awesome glad I made a good choose with the rear. Been debating on the gb or bow ties.. Gb it was since I like them on my sc10,lol.. But as far as the front went couldn't decide on rips or groovy and groovy sounded to much like groove and Kentucky isn't anywhere close to blue groove or packed tracks with groove
all loose dirt on mostly packed clay or something in that nature. But will get them and try it, just wish they had something more aggressive looking,lol...
Bow ties slid too easily for me. I need more side bite for 2wd. Flip outs give that for me. Gonna try GBs this weekend.
Give them a try and let me in on the details and foam you used or if you taped the inside of the tires, I won't be purchasing the kit till get payed next week. I take it your track is like mine in Ky?
GooseBumps are great! Theyre perfect for when theres some loose stuff on top that youd otherwise slide on. Theyll put you through a corner crazy good
Yea I figured they where great since I couldn't find ANY bad info on them other then they wear down quick but I'm willing to sacrifice that for a shirt and plaque,lol.. Just praying groovy will be better then rips for the front of my 22? Fingers crossed.
I have them mounted to cc proline. Track I run loamy and hard packed in spots. That's why flip outs are the ticket when moist. Wet/soaked FOs cake up and I want to try GBs for when it gets a lil muddy. From what u describe I'll run GBs when wet and FOs when dry.
Good luck with that! I'm going to tape my GB and try a firm foam like the Closed cell you mentioned and hope for the best as well but completely lost at what to do for the front tire bite, going groovy over rips and running them as soft as possible :s rear should hook like none other if I can mount them good. Usually have problems with fingers getting stuck to tires and while trying to remove my thumb or pointing finger from the tire I loose a little skin and tire pulls out costing me a wobbly tire,lol..
Have I assembled something wrong here? Seems like the spindle carrier is binding on the a-arm very early in the down travel. Also seems like there is excessive bump steer throughout the limited travel it does have.
Once you set your camber you'll find that interference is gone. Mine did the same thing during build but is fine with the camber set properly.
CSR
CSR
