TLR 22 Racing Buggy Thread
Multiple pads with the shorty pack.
hell with my full pack i only run one strap
ive been running 4wd buggy but just getting a losi 22
looking forward 2 racing another class, just getting a losi 22, im going 2 be racing on clay, and was wondering what motor size 2 run , and what shock oil to start with, and i have some good lipo sadle packs so i was going 2 run them instead of a long pack and was woundering how it would do.
thanks look forward 2 being on the team ....
TLRacing
I have. It steering a lot more in-mid corner, but pushed more off. I prefer 30* total caster.
The short LiPo should help with that. Other than that, try to lengthen your rear camber link. I like 1-B, 3mm inside and 2mm outside.
If you use XXX pads, the front velcro strap will line up to go over the vertical foam, just in front of the bullets.
I finally got to run mine last night.....had to shake a lot of rust off
Car was good other than wanting to over rotate coming through a high speed 90deg onto the straight......each change helped but never really felt stable on the straight either
Anyone else have this problem
Its not tires......setup very similar to evans...other than I had long pack and couple of the others had shorty packs
Didn't wanna add weight to top of tranny cause I felt it was already swaying too much
Can't complain too much as it was my first night with the car
Wanted a shorty but track didn't have one
quick question on the hexes... i see there are standard, .75mm, and 1.5mm hexes.
so does that mean that i can add 1.5 mm to each side to equal 3 total mm to the rear using the 1.5mm hexes, and 1.5mm total using the .75mm hexes?
PW says there will be JConcepts wheels for the 22 available December 1st
You should have hit me up Clint, I had a shorty pack you could have tried. I run the short pack with 1-2 pads standing behind depending on bite that night. I've had good luck with the 1-B camber link in that back with 2mm under the ball stud at the hub and 2.5mm inboard. I've went up to 3* of anti-squat, as the car seems to jump and land nicer. Not sure where you were at ride height wise, but I'm running 24mm front and back, too. Green bar codes and ripps for tires.
Frank/Casper/All -
Finished building my 22. Went together fairly well. Screws were definitely tight gettin in the new TLR plastic!
However, the right side kingpin/caster block connection is binding. You can notice it when you let both arms drop (w/o shocks mounted). There is enough of a gap between the caster block/shim/arm, so that isn't the issue. I believe its becuase the plastic might be a little larger on the caster, or the king pin coating is a touch thicker. Is there a drill bit size I could run through the caster to free it up?
Also, the springs (notabley the front) appear to rub on pre-load adjusment collars, at about 3/4 compression. A noticeable 'click' noise is heard. I have tried to reposition them on the collar/spring cup in numerous ways.
Thx!
Thx!
Have decided to make the switch to the dark side and pick up the 22 Just wanted to know what extra parts to keep in the parts bin, and what parts should be replaced right away with upgraded parts (I.E. aluminum rear hubs, stuff like that).
This car is really hard to break. If you buy extra parts most will sit in the tool box
Also, if you read through this forum, the rear hub bearings blow out easily. Frank Root indicated to buy the losi 8 HD clutch bearings.
Per Frank, refer to the following for other upgrades:
I put them in order of importance, IMO.
Must Have:
Shorty LiPos
3.0* Toe Block
5* Front Castor Blocks
Threaded Front King Pin
3.5* Toe Block (depends on track/driver)
Alum Servo Horn
Nice to have:
Low Friction O-Rings
Titanium Shock Mounts
Alum Rear Camber Brace
Alum Battery Brace
Alum Front Pivot
Alum Washer Set
Threaded Rear Hinge Pin
Titanium Turnbuckles
Alum Shock Tools (plastic ones do come in the kit)
Frank Root -- Losi Project Manager
TLR - Losi - Orion - Spektrum - Xcelorin - Horizon Hobby - UpGrade RC - Rcid - Bradley's Fine Line Designs - Dialed Inc. - liverc.com - Pacific Coast Hobbies.com
Must Have:
Shorty LiPos
3.0* Toe Block
Alum Servo Horn
Nice to have:
Alum Battery Brace
Alum Front Pivot
Alum Washer Set
