TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 09-13-2011, 03:58 PM
  #9826
big chris's Avatar
Trader Rating: 51 (100%+)
There is a guy locally who runs the arms backwards and it does have a bunch of forward traction but I'm not completely sold on the idea. It will wheelie on demand on loose loamy dirt but it just doesn't seem as stable as mine. He beats me all the time with it but I just can't switch it yet. I'm going to build my other roller with the arms switched and see what I think over a long term.
big chris is offline
Old 09-13-2011, 04:22 PM
  #9827
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by racer x 1
Yea ive been running the latest evans set-up and for me it actually doesnt steer enough at low speeds unless i break check the car in there and thats not how i drive so im trying to build on the setup a bit. My 7.5 took a dump in my 4wd soo im gonna try the octa since i already have it and see what happens before i buy another motor( i jus bought a 10.5 sonic motor). Btw where did you get the 82 spur?
The latest Evan's setup (from the Nationals) is for a VERY high grip, very big, outdoor, sweeping track. That setup is a bit different from what we run at WCRC. I would suggest, trying the following changes to that setup:
27.5wt front and rear
1-D rear link
Shorty LiPo
2mm under inside of rear camber link
This will really improve the car for WC.
Originally Posted by kstoracing1
I know a longer link is supposed to give you more weight transfer, right? Lower/higher ball studs does what in theory?
Right now I have it at 1D and 5* got 3* but havent changed it yet.
On the track I do run on there's a 90* turn I treat as a sweeper while entering no problems but it goes into a 180 so there I may lose the rear end if I am not care full. My biggest problems are the 180s at speed. I know if it was a race I want to maintain momentum but I am losing it.
What do you guys do or setup for a 180* switchback?...thanks.
A longer link, will usually let the car roll more. Lowering the inner camber link with do the same, raising it the opposite. I would really but on the 3* LRC. It will be a HUGE change from the 5*. See where you are after that, and let me know, then I will suggest new changes (if needed).
Originally Posted by murky123
how many of you have flipped the rear arms from left to right?
I was a little sceptic at first, but I have driven it myself. and man..its awsome.. love it
rear motor setup 4 LRC block. clay track
do have to put a limiter under the piston with 5 LRC otherwise the dogbone can come out of the outdrive.
Although I have not tried this and I appreciate it might work well for some, the amount of bone angle being put into the car is extreme. This will cause some unpredicatable side effects when driving. I would suggest trying different things to improve rear grip before trying this concept:
Move the battery back
Try a longer rear link (1-B)
Move the wing back
Use a larger spur/pinion (same gearing to move the motor back)
Move hubs forward
Lower rear ride height 1-2mm
Raise front ride height 1-2mm
Run diff slightly tighter
Frank Root is offline
Old 09-13-2011, 04:33 PM
  #9828
I have 5/25 up front and 2.5/3 in rear, 1/D rear link or 1/B the middle front hole. SP speedo@ level 3 launch control. Gonna try 2.
May try 3* caster up front next. See how that feel.
kstoracing1 is offline
Old 09-14-2011, 12:05 AM
  #9829
racer x 1's Avatar
Trader Rating: 27 (100%+)
1-D rear link
Shorty LiPo
lol thats actually where ive ended up. i recently tried the inline spindles and that seemed to help me with low speed steering and Im pretty happy with it this way but the tail end gets unsettled if i push to hard in the little sweeper which i dont like so im planning to throw on the 3 deg caster blocks to see if that will settle the back in the sweeper and then i can just dial a bit of steering out on my radio so my initial isnt tooo crazy. the way the car is now is pretty great butt I think theres sum left in the set up to where its perfect.
ill know after thursday. haha
racer x 1 is offline
Old 09-14-2011, 12:51 AM
  #9830
There's a lot of set-ups for high-bite tracks here. What about a big, open, rough, 1/8 dusty off-road track with lots of fast sweepers, biiiig jumps and a loooong back straight? What set-up would you guys recommend? I have not bought my 22 yet, but would like to compile my Cart carefully before hitting the Order Now button.
lomdel is offline
Old 09-14-2011, 12:52 AM
  #9831
Suspended
lol thats actually where ive ended up. i recently tried the inline spindles and that seemed to help me with low speed steering and Im pretty happy with it this way but the tail end gets unsettled if i push to hard in the little sweeper which i dont like so im planning to throw on the 3 deg caster blocks to see if that will settle the back in the sweeper and then i can just dial a bit of steering out on my radio so my initial isnt tooo crazy. the way the car is now is pretty great but I think theres sum left in the set up to where its perfect.
Don't take away from one end. Fix the rear traction issue at the rear. Unless you have tried everything adjustment wise on the rear. If one end of the car is working good, and one end is not, and you take away from the good end you are just going to have a pile of suck. Also it is but, not butt. Butt means ass!
ifuonlyknew is offline
Old 09-14-2011, 12:58 AM
  #9832
Suspended
An 1/8 scale, but if you must run a 22, Corey Bernardo posted a setup on TLRacing.com for low bite tracks that is suppose to be really good. Good luck trying to drive 22 from half a mile away!
Old 09-14-2011, 06:03 AM
  #9833
celt's Avatar
Default a bit of advice for most new 22 drivers...
This is for non European tracks...
Don't over think it, put Dustin Evans Reedy setup on the car. Leave the rear arms where they belong - "R" is right, "L" is left.
Go drive the car...many packs, half a dozen packs, a dozen packs.
Go drive the car some more, put your wrenches away unless you've broken a part.
Determine for yourself, exactly what might not be working per your driving style / track conditions and make small changes accordingly.
Validate your changes if any...i.e. they must be logical and make sense. "Is this change going to have the desired effect?" I see so many racers complain about a particular attribute, but make changes that will amplify the very aspect they are trying to reduce.
If you have to deviate substantially from this setup, chances are that you have other issues, this setup will get you 95% there with the correct tires for your particular racing surface. If you find the car I think you will (a consistent one), spend that time not tearing the car apart every round but more time practicing your lines and throttle control.
New drivers need to lose this idea that there is a "magical setup" that will take the place of hard work and practice. Your time is much better used by practicing good lines and judicious throttle control. If you don't know the car, you have no chance of tuning it properly. Until you get more experience, you don't know how to tune a car.
It's not always the car, oftentimes it's the driver.
celt is offline
Old 09-14-2011, 06:39 AM
  #9834
gijoe64's Avatar
Trader Rating: 30 (100%+)
Amen!!!!!!!
gijoe64 is offline
Old 09-14-2011, 07:19 AM
  #9835
the big rc's Avatar
Trader Rating: 40 (100%+)
Originally Posted by SupermaxxRich
what setup you running?
Dustins with a few tweaks to fit my style. I added a spacer to the outside camber links in the rear and added the metal 25 degree kick plate.
the big rc is offline
Old 09-14-2011, 08:39 AM
  #9836
TLRacing
Frank Root's Avatar
I would hit up Corey Bernardo. We runs on those types of tracks, has had great success this summer, and is always willing to help.
Old 09-14-2011, 09:07 AM
  #9837
Corey Bernardo's Avatar
Frank what are the chances of you making the 6hour flight east with Kevin and Dustin, to race the Indoor Nationals ? lol
Corey Bernardo is offline
Old 09-14-2011, 09:21 AM
  #9838
TLRacing
Frank Root's Avatar
I wish...lol. Things are busy at work for me, so I may not be able to travel much the rest of this year. Luckily, I live in Socal, and I have plenty of local events to attend
Old 09-14-2011, 09:28 AM
  #9839
Default Losi 22 rear motor
Hello all,
I am all for racing as much as you can without messing
with the set-up to much. but sometimes the car just isn't made
for a specific kind of track.
For the 22 its nemesis is low grip clay tracks.
I am by no means a beginner, I do know my way around set-ups
and I do drive a lot, and I mean a lot.
I couldn't get the 22 to hook on my home track.....at all.
I tried everything, sometimes it worked but only if the track
was moist. When our track was dry and dusty the 22 was probably
the worst car I have ever owned.
I was just about to sell the damn thing when I decided to try the
reversed rear arm trick.
It went from no grip in the rear at all, to all the grip in the world.......
everywhere, out of corners, braking into them, in fast sweepers, tight
hairpins, it jumped better.
I love my 22 with the reversed rear arm trick.
It will probably have its downsides but I haven't experienced them yet.
I can see that this trick will probably result in higher wear for the outdrives and the hub bearings but I will happily replace them a bit more often
when the car handles the way it does now.
my 0,02
Greetings
Hans
Hansie2 is offline
Old 09-14-2011, 10:13 AM
  #9840
Hi Frank, good to hear news from you
thanks
lynx75 is offline
