TLR 22 Racing Buggy Thread
#8418
Need some help here. I'm having difficulty controlling the rear end of the buggy. It wants to slide out from under me, especially off power turns. Its the worst coming end to turns off the long straights. I'm running the evans setup, running clay compound suburbs in the rear and scrubs in the front on a med/high bite track. I decreased the drag break to 10% and that helped a little. I also moved the camber link to 1B and it helped a little but it still feels a little unsteady.
#8419
Sup Ice LOL!
#8421
I believe you are referring to the pivot insert, the ones you are talking about are for use with mid motor and are used to maintain the same tranny height when changing anti squat. They can be used with either HRC or LRC. The anti squat shim is different between the two.
#8422
Just picked up a new kit and I'm nit sure what to do about the servo. I have a hitec 965 lying around that I can install right now but I really want a low profile servo to keep things looking clean. I'm not going to be running mid motor so space isn't a huge issue I guess I just like things looking good. Just wondering what the general consensus is.
#8423
#8425
#8426
Suspended
Well from that pic it looks like the 4.5 "T" block is shorter than the other 4.5 block. So unless they were testing a narrower toe block setup for the buggy (which would require a shorter front block to retain the same amount of toe out of a shorter rear block), I almost guarantee the T refers to truck. What I am wondering is why they would go to a more narrow pivot system for the truck? Thanks for the evidence of the forth coming 22T. Don't bother taking the pic down either as I have already saved a copy of it.
#8428
I might be one of the few people running a full sized 2S battery, sometimes one of my 6000mah25c Dynamites. Primarily I'm running them because a) I already own them, and b) I'm really more focused on 1/8th nitro (I got the 22 for the occasional club race and just practice to hone my skills).
I was on the track with another guy with a 22 who was complaining about his rear end being loose (it was a little dry), with bald Hot Bodies Beams and the 6000mah battery as far forward as it would go (pad behind the battery) I had very balanced grip and the rear didn't try and come around at all really. When the track was wet it gripped just crazy good (this is with a rear motor).
So for me, I like how the big battery feels all the way forward. I can't say whether or not I'd like the 3800mah small lipo better since I don't have one (and probably won't buy one; I already own 6 2S packs, 4 Dynamite 6000's, 2 Reedy 5000's), but I do like the way the bigger battery feels as far forward as it can go.
Just thought I'd share that.
#8429
If so, then are the heights different, where the block rests on the chassis?
The HRC blocks are made to sit 1mm higher than the LRC blocks so the bases should be different if that is what they are meant to be.
Very strange that they clearly mark the LRC and the HRC on the blocks that I have seen and purchased.
To mark a T on yours is interesting, to say the least.
#8430
QUICK QUESTION GUYS! What is the diffrence between the inline spindle set and trailing spindle set. Also whats better? Specific track. Smaller, rutted(tight now) with small/med jumps kinda large sweeper high speed fast track.
http://www.amainhobbies.com/product_...dle-Set-TLR-22
Thanks for the help.
?????Move to next page.
