TLR 22 Racing Buggy Thread
#6166
If I take a pencil or bat and push them with the same object they will push the same distance I have to re center a 3/4 link or a 1 inch link and change the spline so my car goes straight. 1/2 inch horn getting turned 60* is going to move something the same no matter how long or short it is.....
#6170
Well I hit my local track for the first time with my 22 and I must say the 22 felt great out there on the track. I started out running the kit setup and now I want to try the evans setup, but I have a question. I have everything needed to run his setup other than the wider wheel hexes. My question is should I still try running his setup even though I do not have the wider hexes, I dont want to try the setup if the wider hexes are important in this particular setup being that I wont be able to get them til june. Can someone let me know if they have tried the evans setup running the stock rear wheel hexes and how did it perform?, any help would be appreciated.
#6171
#6172
#6174
Battery Strap Mods
Post links and or pictures of the battery strap mods you have seen or done for the 22 so you don't need those velcro straps. Looking for Sadlle Pack ones please
#6176
#6177
Servo is already centered, travels same distance side to side and this guy is asking for more travel to reach lock to lock in both directions.
You want to make a longer link which will throw the wheels to one side.
Then you want to recenter the servo horn on the servo?
With a longer link the servo horn can no longer be at 90 degrees, centered, on the servo.
The link can only be one length, the proper length when adjusted, and still allow the servo and steering rack to both be centered and travel equal distance side to side.
#6179
if you shorten it it will not go as far. I would make it longer... so unscrew the ball cups and have a few threads, possibly more showing. Also after doing this you will need to re center the horn on the servo to make sure your trim is at zero to make the wheels straight. just dont unscrew it too far that the screw will pull out.
Think of having a pencil or a baseball bat in your hand, which one can you reach out and touch something with that is further away...
Dmatter- is your linkage hitting the bulkhead?
#6180
From looking at my chassis, the ONLY way to change anti-squat on an unmodified rear motor car is to virtually disassemble the entire rear half of the car... BUMMER!
Any help or advice is appreciated, as I need to change mine. (the kit 1 degree has me seeking more forward bite, so I want to change to the Evan's setup 2.5 degrees...
Thanks in advance.
