TLR 22 Racing Buggy Thread
#4906
What pinion?
This is the first time I've built from a kit....
What's the pitch that's needed for the pinion?
#4907
I used a trick from the RC airplane world and cut a thin .5mm washer from glow fuel tubing. Once compressed there is no wobble and won't back out at all, it's also super easy to remove no gumming up.
#4908
Regional Moderator
I feel stupid for asking, but here it goes. The wheels on my 22 are pointed right when I turn it on ALOT. What is the proper procedure for getting this right? I can not get all of the right out using the subtrim. Not sure if that matters also but there is also always constant noise coming from servo.
As he noted, I had to cut about 1 mm off 1 ball cup to get the link short enough to have an even throw from r - l.
What brand servo? Mine does that as well, it is a cheap HK servo - it is fine, just noisy.
Ha...beat cha to it Muggydude!
#4909
#4910
It really seems help the car roll more, and "sit on the rear" entering the turn to generate more steering, but it is very controllable. It also finishes and drive off the turn better for me. To sum it up, the car feels like it is driving "less square". I have played around with the shims under the ball studs and settled on .090" (2.25mm) Hub and .060" (1.5mm) Inside. I think it is at a minimum worth trying, let me know what you think!
#4915
Wiring pics
Here is my wiring setup for Mid-motor, everything is between the battery and the low profile servo. Amazingly everything fits, but the wires are a bit of an eyesore, but the weight distribution seems good.
#4916
+1 on the lock nut for front wheel. It looks as though it could be arranged though. Just an axle from another buggy like the kyo one. Might work, I am sure someone will come up with something soon.
Anyone know who makes a chassis protector without the holes cut out? Also how much was the fast lane one? And can they do one that will match my paint? Finished painting will have it up today.
#4920
Maybe, Franks set up calls out everything up front too and the LP servo is a little lighter that a standard. I do have the weight kit now but haven't run it yet. I'm going to give Mid a bit more time as I liked some driving characteristics more than the rear setup.
