TLR 22 Racing Buggy Thread
#4186
Just dropped by Speedtech & picked up a bunch of spares,springs,shock bladders & couple hop-ups. Hopefully getting some front arms & spindles in soon too!
https://www.speedtechrc.com/store/eb...ry.asp?id=1015
#4187
Hey Doug, green double dees with stock foam and groovy fronts with 3/4 rear foam and you good to go no matter what the track is like. Casey also posted my setup from the finals at SRS this past week. If you find that you don't like Dustin's setup you may want to give that a shot. Dustin's really didn't work for me at SRS on wet track. I know wheeler was happy with his car with only a couple changes off of Dustin's setup.
#4189
[/QUOTE]
#4190
#4191
Mine finally showed up , has anyone run both mid motor and rear set ups yet? If so which one did you like better. I built mine for rear motor, but im thinking mid motor and rear weight set may be better for our out door loomy surfaces around here!
What do you guys think?
#4192
#4193
I tried both at a big race this weekend and I couldn't get any steering out of rear motor so I got fedup and went mid motor and drove faster with mid motor but it was kinda sketchy coming out of corners and didn't have the amazing forward bite I'm used to. (this was on an indoor topsoil/clay track that is usually med/low bite but grooves up and sometimes goes to slicks)
I think I will be going back to rear motor though
#4194
So my wife and I discovered an issue with her 22. The gearbox is VERY VERY VERY tight. Last night I picked her car up and tried to spin the spur (were still working on her electronics) and noticed that it barely spun at all... like it was kind of bound up. Assuming something was built wrong, we tore it apart to find everything in order. All the bearings are smooth, all the gears look fine, everything appears to sit pretty normally.. but as soon as you start to just barely tighten the gearbox back together, it completely binds up (4 gear for mid motor). Do we have a bad gearbox housing? Do we just run it and hope it breaks in? Do we call Losi?
Thanks for any advice.
#4197
Regional Moderator
#4199
I just did this step. Page 23, step B-4 (rear motor config). It's the 2 screws (TLR5903) that fix the camber block to the battery tray. In the next step those 2 screws are concealed by the shock tower.
