TLR 22 Racing Buggy Thread
Exotek Rack
I know alot of you guys are asking is the Exotek rack worth it? I personally don't race as often as most of you but I do replace my stock rack once or twice a season due to slop. I think the Exotek will give you that new rack feel the whole season and then some, depending on the bearings life span of course. Only time will tell us that. So I think it's a big plus to have the constant steering geometry over a longer period of time rather than having to install a new rack as the old one gets sloppier and sloppier.
to me it was worth it now that I have the rack installed and have been running it..
On a side note:
Casper saw you running at Pegasus on Saturday, truck looked good.
R/C Tech Elite Member
Ran my 22 for the first time on Saturday. Ran it bone stock on indoor clay. I liked it a lot. Very fun to drive. The last 2wd buggy I had was FT B4 (a few years ago) and I like this one better.
My next step is to try out the D. Evans Reedy Race setup, which a lot of drivers seem to like.
bearings are $1 ea on most sites (avid) so $4 for bearings that should last most people 6 months to a year depending on track conditions. Bearings are easy to clean yourself also.
On a side note:
On a side note:
Thanks. 22T was good all day. I just wish I was able to do a little better with qualifying in the SC classes. I was on pace with the front of field according to lap times in the mains just started too far back. Trucks were all very good and Pegasus track was amazing all day. What a turnaround they have done with thier dirt.
He is a good dude man!
SCT looked good also but the Stadium Trucks seems to love Pegasus.
273 Entries!! That was a lot of racing!!!
Yeah 105 races for the day and track was in perfect shape when it was done. Hats off to those guys!
For those who are using the Exotek rack, are you installing some sort of servo saver? I know the stock setup doesn't have one, but isn't the stock rack sort of the sacrificial part in the whole steering? Seems the Exotek makes everything slop free, but you lose the stock parts that will essentially break and save the servo. Seems $6 for a stock rack isn't bad seeing has how much we spend on tires, wheels, bodies throughout the year.
Run the plastic servo arm if you want a weak link in the steering. They will split and save the servo. I've been running the exotek steering for three races now with the alloy servo arm with a savox 1257 no problems.
For those of you that are running the upgrade thrust bearing. How are they holding up?
V
V
lol, casper I was just thinking about that...
No shims all the way forward, the servo mounts on the back side of the mounts with the exotek setup.
Like Butter
Mr. Casper
I run your setups on my 22T and 22B..... because they work well.
I just ordered the new spring kits one set front one set rear.
Question is: What springs do you recomend for your setups on the
> Buggy: Front/Rear
>Truck : Front/Rear
Im using your current setups... any help apreciated!
> Buggy: Front/Rear
>Truck : Front/Rear
