TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 03-14-2013, 12:08 AM
  #19351
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Wildcat1971
is he running saddle packs?
No, we are all running shorties.
Frank Root is offline
Old 03-14-2013, 07:06 AM
  #19352
gticlay's Avatar
Trader Rating: 14 (100%+)
I think he meant in the mid motor picture I posted...
gticlay is offline
Old 03-14-2013, 07:50 AM
  #19353
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I swapped out the rear plastic camber block for the alum one last night....but I was going to weight them and get an idea of the difference. But i forgot. anyone know the weights? or at least the weight of the alum one? I can weight the plastic when I get home.
Also, the Ti ball studs seemed very tight going in. that normal? I thought maybe I was cross threading it, bit I dont think that is the case. I am using the losi 3x10mm length studs.
Wildcat1971 is offline
Old 03-14-2013, 09:30 AM
  #19354
Trader Rating: 74 (100%+)
general rule is all TLR aluminum pieces weigh 7 grams more than their plastic counterpart
rc23 is offline
Old 03-14-2013, 09:31 AM
  #19355
ok, thx
Old 03-14-2013, 10:51 AM
  #19356
bergie33's Avatar
Trader Rating: 49 (100%+)
Default What car is that
What car is that barely showing at the bottom of the pic?
Originally Posted by gticlay
Hey, look - I'm running mid motor at the Cactus Classic - ON DIRT!
bergie33 is offline
Old 03-14-2013, 10:56 AM
  #19357
brian94066's Avatar
XX4?
brian94066 is offline
Old 03-14-2013, 11:00 AM
  #19358
matt*strike's Avatar
Trader Rating: 41 (100%+)
It doesn't look like the nose of any xx4 body I've ever seen.
matt*strike is offline
  #19359
bergie33's Avatar
Originally Posted by brian94066
XX4?
Actually, now that have done a little more looking around, it looks like a xxx4, not xx4.
bergie33 is offline
Old 03-14-2013, 11:37 AM
  #19360
bigalila's Avatar
It is a XXX4. Wish they would give us a new wheeler!!! Unless of course you mean the one on the left at the bottom... looks like a back-up 22.
bigalila is offline
Old 03-14-2013, 11:43 AM
  #19361
Originally Posted by TekinMan
Anyone running a tekin 17.5 motor in their buggies? I would like to know the best motor timing for it. Im running 32/70 gearing.
I run around 32 degrees of timing and that same gearing on my 22 with the gen2 tekin motor.
It is a XXX4
hacker07 is offline
Old 03-14-2013, 11:47 AM
  #19362
lol, he just want a tlr 4x4 to be made, now you killed his dreams.
Old 03-14-2013, 11:49 AM
  #19363
gticlay's Avatar
Would like to see a shaft drive 4x4.
gticlay is offline
Old 03-14-2013, 04:16 PM
  #19364
[QUOTE=Wildcat1971;11929751]I swapped out the rear plastic camber block for the alum one last night....but I was going to weight them and get an idea of the difference. But i forgot. anyone know the weights? or at least the weight of the alum one? I can weight the plastic when I get home.
Stock plastic= 5.3 grams
Alum= 8.0 grams
And if anyone cares the alum tlr pinion gears are 5grams lighter than steel
tekinACE is offline
Old 03-14-2013, 04:19 PM
  #19365
Thumbs up
+1
2SlowTC is offline
