TLR 22 Racing Buggy Thread
Suspended
THE CHANGE YOU CAN FEEL IS FROM THE DIFFERENCE IN THE DOG BONE PLUNGE NOT THE CHANGE IN CG.
THE CHANGE IN CG IS ROUGHLY THE EQUIVALENT OF PUTTING A SHIM THAT IS .125MM SMALLER ON THE INSIDE BALL STUD. IF YOU WANT TO TRY AND FEEL THE DIFFERENCE THAT JUST THE CHANGE IN THE CG WILL MAKE, PLEASE PUT A .125MM SMALLER SHIM UNDER YOUR INNER BALL STUD AND SEE IF YOU CAN FEEL THE CHANGE.
You said, and I quote
Clearly you have no concept of how the laws of physics apply here. You are wrong if you think the main reason why the 1mm transmission raise does what it does because of the change in CG. I have proved in multiple posts why this is. Everyone knows you are wrong. Try the adjustment or don't.
ifuonlyknew
calm down.....remember the agreement....
that said....i have run the 1mm raised chassis for over a year...in my opinion, the team hasnt used the mod because they are on higher bite....
next time i race my buggy, ill pull it off and see how it goes...
ok, so I have tried the shorty and the full pack. The buggy felt much more calm and less twitchy with the full pack. I was talking to Chuck Hicks at the track and he told me he preferred the short pack in the long config. Then adding weight in the foam for the right balance. And once I get a low po servo, I plan to do the same. As it stands now, I have to remove my receiver connections to remove the battery. I plan to get a low po server and a narrower receiver in a few weeks, but I wanted to see how people are balanacing the buggy weight with a shorty in the short config. Right now, I have 1/2 oz in the front bulk head and the 25 deg brass plate up front for weight. The rest up front is plastic. I have the alum pivot that I can also use and it adds around 20+ grams. Also, in the short config, I can probably get 3/4 oz behind the shorty under the tower also. So I am wonder where and how much weight you would add in s short config. I think in the long run I will end up doing that Chuck suggested, but for now my electronics just dont fit.
Is the tranny mod only for low bite tracks? Would the mod on a high bite track cause a traction role?
It is more for med to low bite tracks but I run it all the time. It will not cause traction rolling but as traction goes up into the high range it may lock in the rear end too much on power.
Excuse my ignorance, but would you use this raised transmission mod with a MM setup to achieve the same results? Thanks.
Is there something else being done in place of the raised trans? shimming axles and bones further into the outdrives perhaps? are both those things being done together by some?
in need of a better driver , gna grab the mip this time. do i need a 2.0 or a 2.5 for most of the screws.
thanks alot.
thanks alot.
most of the car is 2.0mm
Hey, look - I'm running mid motor at the Cactus Classic - ON DIRT!
Yes, it's in the same Jconcepts blog post I found this pic at. Can you imagine having to mount new tires for each and every time you run your car in practice and racing? $$$$$
