TLR 22 Racing Buggy Thread
No thats what the thrust bearing does - it allows one side of the diff to spin at a different speed than the other while maintaining tension on the diff gear and not backing out.
I guess I can read the entire thread (1235 pages) or if someone can easily answer which mods are needed for clay med/high grip, medium size indoor track? Also how about a setup sheet that someone can provide me with? Car is setup for mod 8.5T
Thanks!
Thanks!
[email protected]
Thanks!
[email protected]
Thanks!
http://www.petitrc.com/setup/losi/Se...TwentyTwo.html
I like this one!
http://www.petitrc.com/setup/losi/se..._OCRC20120924/
When converting shocks to emulsion... are you guys allowing rebound or is a dead shock better?
New to offroad buggy racing
I currently have the B4.1 RTR (some mods) but I really like the looks of the TLR 22. I have been racing at my LHS for about two months (not really competetive yet). I am thinking about pruchasing the 22 and wanted to know if anyone thinks it will help me to switch or should I just keep the B4.1 and get more wheel time?
Dead. You can't really run emulsion with rebound.
In all honesty at this point more wheel time will make you a better driver. As Chevmaro said the B4.1 is a very capable car, whilst I would give the 22 the NOD for durability it can be a bit of a PITA for setting up though (untill Frank Roots Standard Setup).
If I was you, I would save my cash and do the following.
1) If still using the RTR Radio, ditch that and pick up a good radio. Something like a Futaba 4PL or Sanwa/Airtronics MT4. Both are good radios and will serve you for a very long time.
2) Get more wheels and tyres, Ask around at the track see what the favourite is. Personally I like AKA Rebars for a variety of Conditions and ProLine Holeshots are considered the "standard". I also really like JConcepts Double Dee's.
3) Spare front A Arms for your car
4) Variety of Shock Oils and Springs.
Oh and read this from cover to cover
http://www.petitrc.com/reglages/RC_HandbookV3-4.pdf
Eventually you will have no problem driving and if you really want a 22, get one. I did.
I agree with the durability of the TLR22. Can't go wrong there. Although Cloaked is giving sound advice as well. Can't really go wrong either way...
Have a question for you 22 pros! I just switched over to the 22, have it pretty close to where I want it but need to know what I can do to stop the car from over rotating in exit. On power the rear follows the front around but wants to continue the rotation when I need it to square up! Thanks in advance
http://losiracing.blogspot.com.au/20...2-and-22t.html
My car is ridiculously easier to control coming out of corners now.
