TLR 22 Racing Buggy Thread
Been out of the 1/10 scene for a while, have a few quick questions.
First, whats the scoop on the transmission spacers?
Also, does anyone have a really good high bite, tight, small indoor clay setup? I'm trying to get my car to turn and rotate more. Especially on power. Thanks
One more thing. Has anyone tried running a shorter chassis? I know at least one company who makes them.
Thanks guys
Thanks guys
http://www.tlracing.com/Products/Def...022#prodSetups
this for the tranny mod:
http://losiracing.blogspot.com/2012/...2-and-22t.html
2wd vs. 4wd is a little different, but what I have found is that every change is relative to where the setup is currently at versus the grip of the surface. In TC, the grip is usually always realtively high, so more roll will often create more grip. Often in off-road, more roll with exceed the lower grip surface and create less grip at that end, just as an example of how the 2 diciplines can be different.
can you describe the dirt conditions that should favor an lrc setup? i'm not seeing the upside to unloading the inner wheels with roll, compressing the suspension and possibly running positive camber thru the turn. thanks in advance.
TLRacing
i'm still quite new, so bear with me. on a dry, hard, twisty track i'm digging my rear-motor hrc setup front and rear. despite the twisties, i'm also running max wheelbase to help with on-power steering and end of straight braking stability.
Whats the best way to position a Shorty Lipo in the 22?
Rear or Towards the front?
the man has returned! i think you will need to update your set up guide! lol
I'll be talking to Matt C too, obviously really nice to have him at the local track!
I wouldn't even know where to start with the guide.
If you guys want me to add some stuff just list it here I guess and I'll put it in.
I am tempted to try the shorter chassis, I only run rear motor and shorty battery so that's not an issue.
That all depends, usually I run it middle, but if you want more or less rear traction, you can move it forward or back more.
I have my car configured where I can run a full sized pack at any time. I typically only run a shorty and typically run it with one pad laid down in front of the battery. I'll move it back sometimes for more rear weight bias.
Back from my first race day with my TLR 22!!!
I freaking love this car!!!
Trinity D3.5 17.5T is in other class than my friends Revtech 17.5T with ht rotor. I started off with 32/70 gearing and in Blinky with no endbell timing it was keeping up to his Revtech with 33/70 gearing and max endbell timing. Mind also came off the track at 102* vs his at 125* after the first heat.
Didn't bring any other pinions with me so I just plugged up the Hotwire and maxed out the boost and left the endbell at 0. Was keeping up with some SCTs running 10.5T motors.
Ran the second heat and after 8 minutes it was just 120* so I have even more room to go up.
Went ahead and added 15* of turbo and while it was stupid fast it was just too much for the short straight away since even with a .15 delay it kicked in too late and didn't really help.
Switched from the JConcept Groovy to the Barcode up front and it really tamed down the steering since traction was so hard to find.
Double Dees did okay but the track was very loamy compared to normal and they caked up a little bit and didn't do as good as when the track is dry and dusty. Any suggestions in a batter tire?
Hey guys been out of racing for a long time started racing a scte an I really want a 22. My problem is I bought one on here as a roller now after studying the pics it is a rtr 22 not the race one. Hate myself. Is all the difference just the mid motor mount the Tim nitride shock shafts and hinge pins and the ball diff? Or is the rtr a junk replica like kyosho stuff? (kyosho rtr mostly garbage compared to kit). Basically It isn't shipped yet and I am hoping to get a refund. Please any help would be appreciated
I guess it would really depend on the price to keep it or look for a race version . Other than the diff I really wouldn`t sweat it as many people seem to like the gear diff . Good luck in which way you go .
Thanks it was 165 shipped
the plastic shock caps in the RTR are great, I wouldnt change the hinge pins, and the shock shafts can only be betetr than the kit ones.
The titan shock shafts are really bad and if you could buy the steel oney I would try them but you can only buy the titan ones as spare.
I would go for the ball diff though, but Asso diff should fit too (maybe even kyosho) depands what you already have I would have a look first before buying the TLR ball diff. If you want to start with the gear diff start with 5000 cps
It takes the same oil as scte diffs? Start at 5000. I appreciate the help I will look for a ball diff on here. So I shouldn't be too worried that it's the rtr
Losi big shots for loam and bumpy surfaces.
