TLR 22 Racing Buggy Thread
The bleeder shock caps definitely make the shocks rebuild quite simple. If you are looking to save some money you can consider LOSA5006.
http://www.horizonhobby.com/webapp/w...pe=productgrid
Thanks just put order for protek bearings on amain
Whats a good outside clay/dirt set up and tire? I'm going to take the buggy out on the dirt track for the 1st time next Sunday.
if its a dry/dusty track double dees super soft, if its moist and tacky bar codes super soft. those are the only two tires for the rear i keep around for my 22. i am the farthest thing from a pro though! but ive never had complaints with em.
Besides the motor, servo, and receiver, can anyone tell me if there is a difference between the kit 22 and the RTR 22? I'm starting over on a very limited budget so the RTR package is going to be my starting point. The RTR kit appears to have aluminum shock caps and other similar features that make the kit great.
ok i like to get a novak motor and esc for my 22 . i have mmp esc with a 5700 kv 4 pole motor its to much power in it . like to get a novak set up now. what trun to go with?
depends on what class you're planning on running. 17.5 is a solid choice that is drivable for most folks. if you're a lil more used to the buggy then the sky is the limit with how fast you want it. The real question on the motor is how big is your track, and will you use all the RPMs that a lower turn will give you. on a super tight technical track a 17.5 will probably out race an 8.5. But take the same two buggies and put them on something closer to 8th scale size and that 8.5 is going to make that 17.5 look slow on the straights.
i just play so 8.5 trun will do.
http://www.amainhobbies.com/product_...tor-Combo-175T
or
http://www.amainhobbies.com/product_...tor-Combo-135T
Save yourself the trouble and get the right thing for the job, the FIRST time around, instead of just 'settling' with a non-competitive substitute.
or
or
or
or
The Tekin RS ESC's have far more adjustability and customizable settings, with greater overhead for improving performance in areas, where others fall flat
It's not anyone's opinion, it's proven [and professional's] experience.
i like the 13.5 set up thanks.
