Losi 810E - The Ultra Lightweight Electric 1/8
#631
I'm at the same crossroad as you. An Aluminum or try another CF... The stock towers are cheap stamped aluminum and I was thinking the beefier TLR aluminum towers might be better for the front. I think they'd be quite a bit stronger than the CF ones and might resist bending more than the stock.
#632
Reading this thread for kicks and might as well chime in for you on the machined aluminum towers since I own a set, and have for over a year.
They've been awesome and extremely durable on my SCTE. They were previously on my Ten-T and took some seriously hard big crashes on an 8th scale track with huge jumps and haven't bent or broken yet.
So far they're 1/8th scale durable.
...I bent the stock ones in a week.
#634
#636
Hey guys I've got a question here. I have a Ten-T and I want to run a Castle 1410 on 2s. The Ten-te thread doesn't seem to have anyone running that motor so I'll ask here. Is there a big difference in weight and rotational mass from the 810e to a Ten-te? I see there has been people running the 1410 towards the beginning of this thread with no issues. I've got the Losi 320 size wheels and tires not the stock tires if that helps anything. Any info would be greatly appreciated. One last thing what pinion should I start with?
#637
I'm sure that, had the CF been on my TEN-T or on an SCTE, they wouldn't have broken either. The issue is that, on buggies, the front tower is exposed. Miss a jump and the tower generally takes the full brunt of the ground. Ultimately, them being exposed is what caused the breakage, not the awkard landings.
Also keep in mind that the machined towers for the TEN are the exact same material and thickness as the ones that the 8ight buggy uses. I don't see many people having issues with them bending or breaking at my local track on the 8ight buggy.
#639
Pinion would depend on what Kv motor you decide to run. I found that 15 on my CC 151 works well. So i'd recommend running that first.
True enough, although I did bend the stock ones really easily.
#640
after market chassis
Does anyone make an after market carbon fiber chassis for the 810?
#642
