Losi 810E - The Ultra Lightweight Electric 1/8
#496
i ran this combo for the first time last weekend. i started with a 17T pinion with a bore reducer adapter. it came off in the first qual. i next went with an ofna 1/8" 16T. i liked the 17T better, but the 16 still worked. if you have faith in the bore reducers, i'd start with a 17T.
#497
Thanks for the heads up on the servo horn. I know they crap out easily. I haven't had good luck with the aluminum horn though since they wear against metal gear servos, since aluminum is softer. I rather use Dubro composite horns.
#498
Im searching a losi 810 ........ if anyone interested in sell contact me with private messages .....
#500
Im searching for a losi 810 ........ if anyone interested in sell contact me ASAP with private messages .....
#502
So I picked up a roller to have some fun with. Doubt it will ever get raced, just fun time at 2 tracks, one small, one medium, both outdoor.
Have MMP and 3800 4 pole motor.
Will 2s be okay or do I have to go 3s?
Thought about just getting a Pro4 4000 or 4600. Not too much info on these in this thread, but plenty on them in the scte thread.
#506
Gathering parts, here is what is in the mail.
Losi:
Hard anodized shock bodies f/r
aluminum suspension mounts f/r
graphite towers f/r
8ight wing mount
spring tuning kits f/r
hard anodized aluminum suspension balls
RCM
light weight battery tray
Castle
2400 kv with 5mm shaft
Lunsford
Ti turnbuckles
Have MMP and some 2s and 3s batt's sitting around. Can't wait for the snow to melt.
Losi:
graphite towers f/r
8ight wing mount
RCM
Castle
Lunsford
Ti turnbuckles
#508
Just ran the buggy on my sidewalk, yard and street for the first time. Ran the buggy stock, with CC 2400 kV motor and 3s. WOW. Almost seemed overpowered. I ran a 17t pinion with stock spur. I punched the throttle and it flipped instantly. I could be rolling at about 40% throttle and pin it and it would wheelie forever.
#510
Try 3S and go down a couple teeth on the pinion. I normally run a SC4X 7.5 on 3S and it's quick, but nowhere near the punch of a 4S 1/8 buggy setup. I get a 5.5 on 3S with the right gearing will be very fast. Heat will be the issue. Cut a lot of vents in the body.
