B44.1 Thread
#1276
will try em
my protek saddle pack died overnight, it never has problem for a year, I was given it, had it for 6 months now and 2 nights ago I charged it to 8.4 but I had to go before is was fully done, Next day i plug it in and it says error low voltage...Nothing was touched. My esc doesn't turn on with that battery also. I worked fine 2 days ago at the track.. always charged it, ran 8 min at most..
how is the gens ace? 4800
#1277
Registered User
will try em
#1279
will try em
#1280
will try em
#1282
#1284
I have the sticks.....ran in a Hyper sc...faded towards the end and don't care for them. Promatch batteries from now on. Any new ones I get will be promatch..no fade and good prices.
I have Orion 45c good batteries over priced compared the promatch tho.
Go on the high velocity thread and check out what he has also.
#1285
The balls (carbide/ceramic) or rings won't were out if you maintain them, keep them lubed. Make sure to open the diffs every 8-10 races, check for wear. If you stay on top of the maintenance you'll be good. Your enemy is friction!!
#1286
Thinking about getting all the different springs available for the B44, the hobby shop I'm buying from has 10,15,20,25,30,35,40,50,60 weight oils available. What range do you guys think would be practical to be able to tune the full range of springs available.
#1288
Don't get me wrong I'm not doubting your feedback of the range of 25 to 40, do you beleive that all the perfect weights for such a range of springs could be found in that range. I have seen other weights graduations inbetween the ones I have listed available elsewhere.
#1290
1Likes
