Like Tree1Likes
B44.1 Thread
Old 09-28-2012 | 06:56 PM
  #2791
Bburns's Avatar
Originally Posted by Wease
I think I'm only going to add the big bores to my 44.1 as well. Do you need the new towers to run the big bores, or will they work on the 44.1 towers?
. . . Matt
You don't need the new towers if you don't want them. The bb shock kit comes with spacers to mount them.
Bburns is offline
Old 09-28-2012 | 09:42 PM
  #2792
MOmo's Avatar
Originally Posted by johnbugman
Looks really good. Something to be proud of.
Thanks. I like how it turned out too.
I'm running stock shocks with kyosho springs and have never had a $100 dollar extra problem plus new shock towers to validate new struts and everything else that needs to be purchased. People are always looking to buy a better game. This is not a reflection of you I'm just stating the facts.
I spoke to my friend at AE, who had a hand in the design, and he told me that the tower is a tad more aggressive in design as well as the addition of a 3rd hole. The arms have been beefed up. Not necessarily a must, but could be worth a look. As for adjusting for BB, as stated, those running the other BB springs (avid, losi, or Kyo) have just spaced them accordingly.
I found the parts list for the new 44.2 and did the math. Most everything is the same other than the BB, towers, chassis, slipper, upper decks, rear CVA, and the battery tray/straps. When I totaled everything I would need, it came in Under $150 (W/O the BB factored in). I got my car for WAAAAAAY below the Tower price (even below dealer cost) and figured if the conversion came in less than the going rate for the new B44.2 kit, then i might just convert my existing car. Tower lists the car at $370. I figure if i can get everything for around $150, I think I'm doing good,
MOmo
MOmo is offline
Old 09-28-2012 | 10:54 PM
  #2793
I got closet to 300 for all the parts, Slipper, slipper shaft, New body all the graphite, and with shocks. Looking at 300 to convert a 44.1 to a 44.2. Shock towers front and rear are thicker. Who is your bud at AE. KNow a few peeps there also.
ALIEN3T is offline
Old 09-30-2012 | 03:22 PM
  #2794
I just bought a used b44.1 I'm going thru the diffs is everyone shimming it the same way the manual says to or is there a different way I should shim the diff ?
josh short is offline
Old 09-30-2012 | 03:30 PM
  #2795
rigor's Avatar
Ignore the manual and use the B44.2 manual, as they finally corrected the shimming section. 6 on the gear side, 3 on the other. There should be ZERO side to side play once placed in the transmission casing. If it feels slightly tight, don't worry, it'll loosen up within a couple runs.
http://www.teamassociated.com/manuals/B44.2/
rigor is offline
Old 09-30-2012 | 04:05 PM
  #2796
Ok thank. U
Old 10-01-2012 | 07:02 AM
  #2797
bergie33's Avatar
Default B44.2 battery straps
If I want the quick release battery straps from the B44.2 in my B44.1, can I just get the straps and hardware (ASC9906) or do I need the cradles too?
bergie33 is offline
Old 10-01-2012 | 07:51 AM
  #2798
Has anyone run the avid triad slipper as well as the vst slipper for the 4x4 sc10? Are they worth it? I read that the garolite pads are pretty legit as well. What are the differences in between the three different setups?
adamym is offline
Old 10-01-2012 | 09:35 AM
  #2799
TJMac's Avatar
I think you need the cradle as well. I want to do the same thing, the thumb nuts are PITA.
TJMac is offline
Old 10-01-2012 | 01:40 PM
  #2800
Suspended
You can't use the vts in the 44.1 you have to get the 44.2 chassie and if you get that you need the top decks. I here the avid triad is well worth it.
CT RACER is offline
Old 10-01-2012 | 01:52 PM
  #2801
Jmuck69's Avatar
PDub mentioned that a spacer will be available for the Triad when used in the B44.2 due to the increased distance of the bulkheads.
Jmuck69 is offline
Old 10-01-2012 | 02:29 PM
  #2802
bergie33's Avatar
I am thinking that the FT shafts that hold the thumb screws should also be able to hold the ball stud and quick release from the 44.2 straps.
bergie33 is offline
Old 10-01-2012 | 02:53 PM
  #2803
WEll i know WEST Coast RC in Cali just got the BB shock kits in today.
ALIEN3T is offline
Old 10-01-2012 | 06:41 PM
  #2804
JEFFs SC10's Avatar
so is everyone trying to dump off their 44.1 for the 44.2? LOL
JEFFs SC10 is offline
Old 10-01-2012 | 07:26 PM
  #2805
Suspended
so you can use both for the 44.2 and just the traid for the 44.2.
CT RACER is offline
