Like Tree1Likes
B44.1 Thread
Old 05-02-2012 | 05:42 PM
  #2041
Suspended
Originally Posted by elex300
Well I decided to go with the 44 platform over the Rango. Mainly because I alreadyhave a SC10 and a B4.1 so it makes things easier. So what are the upgrades the 44.1 has over the 44. I can get a 44 lightly used quite a bit cheaper. It has the V2 parts and lipo cradle already. Just curious as to why I should go the 44.1 route over the 44.
Well the .1 chassie is narrower but if you can get your hands on a 44 for a good price with the v2 upgrades i would take it.
CT RACER is offline
Old 05-02-2012 | 06:37 PM
  #2042
In my opinion the shocks are about the only thing that makes much difference, and that is really just ease of maintenance.
I actually think the 44 chassis with the nimh cell cutouts is better if you run the AE chassis tape to keep the cutouts from digging into the dirt.
You can easily trim the 44 chassis to match the 44.1 chassis.
Bike racer is offline
  #2043
elex300's Avatar
Thanks James, That's what I think too. I found a sweet deal on one with motor,esc,and saddles. I can always buy a chassis if I stick to the class.
P.S. What happened to the mini king? No more onroad? Jeff's wont be the same.
elex300 is offline
Old 05-02-2012 | 07:16 PM
  #2044
Originally Posted by fastchvy
I started with white also but went to yellow in the rear, white made it donkey kick a little, yellow is much better. If you try yellow let me know what you think. Im running the carbon c hub also, gave it a ton more rear grip.
I'll give it a try. Are you racing Friday night?
- Terry
TeamOSG is offline
Old 05-02-2012 | 07:18 PM
  #2045
Originally Posted by TeamOSG
Avid purple fronts and white rears are working well at WCRC. I have only one practice day on them but they are good all around the track. Holds well on the sweeper and gives better "pop" on the triple. Stock pistons with 35/30 Losi oil.
When you say stock pistons are you talking about 2-2 or 3-2. I have seen several set ups using 2-2,. I too use Losi 35 and 30. Like the way it feels.
zipperfoot is offline
Old 05-02-2012 | 09:04 PM
  #2046
fastchvy's Avatar
- Terry
No, but i will be there all day saturday
fastchvy is offline
Old 05-02-2012 | 10:19 PM
  #2047
bergie33's Avatar
Default My new B44.1
I think I have a crush on my new B44.1. Raced it today for the first time. I am definitely in love.
bergie33 is offline
Old 05-02-2012 | 10:21 PM
  #2048
fastchvy's Avatar
You run a 13.5 in the b44.1?
fastchvy is offline
Old 05-03-2012 | 12:42 AM
  #2049
Originally Posted by zipperfoot
When you say stock pistons are you talking about 2-2 or 3-2. I have seen several set ups using 2-2, but the worlds kit calls for 3-2. I too use Losi 35 and 30. Like the way it feels.
2-2
I also tried the MIP Bypass 1 valves. I ran them in compression, rebound, and mixed. I had to go up in oil wt when using them. For now, I went back to the stock pistons because want to see how much the springs help before I start changing more things.
TeamOSG is offline
Old 05-03-2012 | 05:21 AM
  #2050
john watkins's Avatar
Hey guys,
Quick questions for you spring rate experts.
I just made the switch to avid big bore springs... Anyway... The standard b44.1 silver spring is 2.85 lb but the heaviest front buggy spring avid has is 2.61. Will this be sufficient ? Is this an oversight? Or perhaps spring rates don't transfer across from standards springs to big bore springs and if that is the case which front avid spring should I use?
Thanks in advance
Cheers
John
john watkins is offline
Old 05-03-2012 | 08:17 AM
  #2051
fastchvy's Avatar
Originally Posted by john watkins
Hey guys,
Thanks in advance
Cheers
John
Run purple in the front with #2 piston 35wt ae oil, yellow on the rear #1 piston ae 30wt oil
fastchvy is offline
Old 05-03-2012 | 08:36 AM
  #2052
SFtifosi's Avatar
Would you be able to elaborate on this? I'm a nitro guy, but I took a short break from R/C and I'm back and trying my hand at electric. I would love to stick with NiMH for a bit as it's what I know (from waaay back) and I won't be on a steep learning curve going with LiPo.
Does anyone even make loose, NiMH cells anymore? I kinda miss building battery packs.
SFtifosi is offline
Old 05-03-2012 | 08:58 AM
  #2053
20 SMOKE's Avatar
just leave the chassis stock its just fine,there are a few cells out there but for the money you can get better runtime with lipo so i would just run lipo
20 SMOKE is offline
Old 05-03-2012 | 10:15 AM
  #2054
SFtifosi's Avatar
Are all the horror stories about people burning their houses down that common? I never feared for my life while charging NiMH.... Just seems like a hassle for a couple more minutes runtime. Do they weight that much less? Is that a big advantage of LiPo? Remember, nitro guy here...
SFtifosi is offline
Old 05-03-2012 | 10:51 AM
  #2055
Lithium based batteries have 3x the energy density when compared to Nickel based battery. So the same capacity battery will weigh 1/3 the weight in lithium vs. Nickel.
mulepic is offline
