Like Tree1Likes
B44.1 Thread
Old 04-27-2012 | 07:35 PM
  #1981
There are 4 lipo cells involved in a saddle pack. For example, on a 4200mah, 2cell, 7.4v saddle pac..... Each side of the pac has two cells wired in series for 7.4v nominal. The individual side is good for 2100mah at 7.4v. Then these two sides are wired in parallel to yield the final mah.
Dont believe me? There is a person with the screen name duster 360. He has posted many messages about wiring. Look him up.
zipperfoot is offline
Old 04-27-2012 | 07:54 PM
  #1982
TJMac's Avatar
No. A 2S (not 2S2P) saddle pack has two lipo cells total. One in each of the two packs. Each pack is 3.7v @ whatever the mah is for the entire battery. EX: AE 5200mah 7.4 saddle pack - each of the two packs is 1s (one lipo cell), 3.7v, 5200mah. If each of the two packs contained two lipo cells you would need two balance leads ( they only use one) and in fact, you can charge each pack separately without using a balance lead (nothing to balance as its one lipo cell).
TJMac is offline
Old 04-27-2012 | 08:26 PM
  #1983
TJMac's Avatar
Yeah I've read his posts, and he's right. A 2S2P lipo does indeed have four lipo cells. The problem is they aren't all 2S2P.
TJMac is offline
Old 04-27-2012 | 08:54 PM
  #1984
That is what I have just learned. I looked at several packs. The Reedy pack I looked at was two cells, the Orion I looked at is available in a variety of configurations, The Protek saddle pack I just looked at on Amainhobbies.com is listed as a 3P2S, which is depicted in the diagram below. SO in fact you can have 1, 2 or 3 cells per side, and still get the 7.4v, and one balance connector.
Take a look at http://scriptasylum.com/rc_speed/lipo.html. You can play around with different types of configs. Pretty interesting.
Attachment 913757
Old 04-27-2012 | 10:29 PM
  #1985
fastchvy's Avatar
1,2,3 cells per side? Wow!....lmao
fastchvy is offline
Old 04-28-2012 | 07:02 AM
  #1986
UN4RACING's Avatar
Attachment 913757
How about a link to the site you are using for this info? LOL never mind
UN4RACING is offline
Old 04-28-2012 | 10:29 AM
  #1987
smittyusmc's Avatar
Ok guys so I have a Orion vortex R10 pro in my b4 right now I am running a 17.5 in it but I will soon to be putting in 8.5t. My question is I was going to buy the vortex r10 race with a 6.5t in my b44. Would it be better to put the pro in the b44 or will the race be fine.
Also what is the big diff between the pro and the race? Thanks for your help q
smittyusmc is offline
Old 04-28-2012 | 05:13 PM
  #1988
Anybody know what parts are needed to use the big bore kyosho shocks?? I already have them and there not mounting to the shock tower properly, also how many mm of downtravel limiters do i need in them??
rickybobbyxxx is offline
Old 04-28-2012 | 05:31 PM
  #1989
What length shocks did you buy? 30mm fronts and 38mm rears? You may need to get some longer screws and space them away from the tower, but other than that they should fit just fine. Look back a few pages page 116 #1737 and check out my pics with my standard velvets with BB springs on them. I put 2 limiters in the back and one up front to keep the dog bones from popping out. I used the losi bottom cups and associated 1779 FT shock eyes to get the right lengths and travel needed. I've also been using losi yellow rear springs and blue fronts. I hope this helps.
nhraman is offline
Old 04-28-2012 | 06:10 PM
  #1990
Havnt measured them but it says complete big bore shock set for rb5 and zx5.
Old 04-28-2012 | 07:37 PM
  #1991
Those should work fine then.
nhraman is offline
Old 04-28-2012 | 07:40 PM
  #1992
Ok thanks , i must be missing something
Old 04-28-2012 | 07:53 PM
  #1993
What top caps are you using? Use the longer ones on the front if necessary.
nhraman is offline
Old 04-28-2012 | 07:58 PM
  #1994
Not sure what u mean
Old 04-28-2012 | 08:07 PM
  #1995
on the black parts tree was there both short and tall top caps? (top shock cap with eyelet)
http://www.amainhobbies.com/product_...ront-Shock-Set
nhraman is offline
