Hyper TT 4wd 1/10th Truggy Thread
#3376
I just picked up a roller from a member on here. Installed a castle sct,1410 combo.All i can say is wow!! these little truggies can handle and jump.It is way faster than my blitz and is perfect for my backyard track. where my STRR-E is just to big to get around it fast.I was worried about durability but i haven't broken anything even on 50 degree days and big air jumps. I just wish these would have caught on.Tires are so much cheaper than 1/8 truggy. I am running the nitrohouse setup with double dee's tires and it works great.
#3377
#3378
3s, blitz tires, and kids driving with ABSOLUTELY NO throttle control LOL
The blitz tires grip more than the Badlands i had on the Rustler..
#3379
I have the Aluminum front knuckles that a fellow member made on my TT. anyone else experiencing slop where the pivot balls are? Any fix for this?
#3380
I'd like to see a shim of some kind to go between the cover and the front of the ball. I thought about a thin oring but i think that would cause it to bind..
#3381
Used team driver set up, worked pretty good.
#3382
#3385
http://youtu.be/JkFTFkEutNY
Don't mind my driving.
#3386
Thanks, broke at the end damn plastic rear hubs. Running 3500 velineon, spc 3s, 11-42 gear. The guy with the blue truck is Rick Jenkins, team driver for Caster pretty fast. The SC trucks are a lot bigger than are little tt's, all the SC guys are running 8th scale systems in there trucks 2200-2650 castle. I will say the tt's are quicker and jump better, but the SC trucks turn on a dime and don't sit on there lids when they flip, they roll back on there wheels. And that class is 4x4 Short Course.
#3387
Hyper Mini STE to a Hyper 10TT
Anyone convert a Hyper Mini STE to a Hyper 10TT???
I was told it was only a few parts to change over but can't seem to find a thread or much info.
chassis
drive shafts
shock?
towers?
body
chassis
drive shafts
shock?
towers?
body
#3388
I am pretty sure it is only the chassis, front and rear drive shafts and body. Every thing else is the same. If you want to split hairs then the wheels and tires are different also, but most people change wheels and tires like there underwear, too often and not often enough. LOL JK.
#3389
Thanks ambryatim
Anyone have a list of bodies that will work with the TT?
I have seen a Chevy body on one but forgot to ask if it was 1/10 scale or something smaller.
#3390
The lower chassis plate that sits under the center diff also.
The inside lower arm retainers are different also. TT and SC have tabs on the bottom to lock the sides on the chassis. STE's are flat. STE's are also obsolete. I just bought the TT version and cut off the tab...
