Team Associated RC8Be Thread >
Old 09-03-2010 | 09:28 AM
  #301
Unhappy truble with gears
i just put in a mamba motor with the pinion gear it came with.
its vary loud and the gear sliped off!
what caused this to happen and how can i fix it?
thanks.
garrettsalaets is offline
Old 09-03-2010 | 09:56 AM
  #302
Did you use Locktite on the set screw.
Woodbutcher is offline
Old 09-03-2010 | 09:58 AM
  #303
jboquire's Avatar
thanks.
If Im not mistaken, the gear that comes with the mamba combo is a .8 mod, you need a 1.0 mod pinion for the rc8be. Now if you used the one that came with the car kit, then it was probably your mesh, you only need a little play between the spur and the pinion and make sure to check the gap at 0, 90, 180 and 270 deg.
jbo
jboquire is offline
Old 09-03-2010 | 10:07 AM
  #304
LiqrSicc's Avatar
Talking
Well I gave in and ordered one last night and got it this morning. Anybody have any pointers on the what diff fluid wt to use on a bashing setup?
LiqrSicc is offline
Old 09-03-2010 | 10:59 AM
  #305
snrscion's Avatar
Registered User
thanks.
The Mamba does not come with a mod 1 gear. That gear that it came with is for REVO that why it so noisy.
snrscion is offline
Old 09-03-2010 | 03:12 PM
  #306
millerdui's Avatar
gettin good run times with my 2650 mah and rx8/1400 combo.gettin 12 min easy, havent went all the way to lvc but at 12 mins i show 15% on my charger so that is good enough for the 10min mains we run around here. the lighter weight of the buggy is awsome. have to run the short wheel base to keep a lil more weight on the rear but i am going to try 553 diff set up vs the 575 i have now.
SNRSCION- hope you got some more chassis's about ready. I will have some money to blow on the 25th!
millerdui is offline
Old 09-03-2010 | 09:19 PM
  #307
snrscion's Avatar
Registered User
Ok no problem.
snrscion is offline
Old 09-05-2010 | 03:40 PM
  #308
Audiobahnaholic's Avatar
Is anyone running the 50t spur on the buggy? I am running 46/16 in mine right now and it feels like it has too much torque (wheelies) and lacking top end with a Tekin RX8 2050 combo. I was thinking of going like 50/18 or 46/17. Which would be better?
Audiobahnaholic is offline
Old 09-05-2010 | 03:44 PM
  #309
You're undergeared a few teeth. You should be more like 44/18 or 44/17 if you have 208 software and are running ~10 deg dynamic timing. Assuming you're running on a medium to large track.
Stealth_RT is offline
Old 09-05-2010 | 03:46 PM
  #310
I'm running 4s as well. I don't have hotwire yet so I am stuck with what i got.
Old 09-05-2010 | 04:57 PM
  #311
Michael#81's Avatar
With this setup you need to be about a 46/20-21 to get the performance you are looking for.
Michael#81 is offline
Old 09-05-2010 | 05:02 PM
  #312
brickshouse's Avatar
I have same setup, you need to run 46/18-20 depending on application
brickshouse is offline
Old 09-05-2010 | 05:20 PM
  #313
Are you running 4s
Old 09-05-2010 | 08:18 PM
  #314
helmsey's Avatar
What servo should I be looking for to steer one of these? Would like to keep it in the $50 range. Initial thought was a Hitec HS-645MG, anything wrong with the servo in this buggy?
helmsey is offline
Old 09-05-2010 | 08:40 PM
  #315
BMenard17's Avatar
I use this servo and it gets the job done but seems a little weak IMO but I dont like super fast steering either. LOL I just noticed you are in knox, im in maryville. do u go out to karns raceway?
BMenard17 is offline
