Made a number of changes to the car on Friday and wow, what a difference. Finally got some steering out of it! Basically running the Cav Reedy setup. Didnt have time to install everything that came in last week but for the first qual, I ran the carbon front arms and the front shocks with 35wt, #2 pistons, 2 limiters, Avid white springs (back was still kit setup), and a full size battery (thin pad forward). Car had tons of steering and felt pretty good out back too. We only had 5 heats so I barely had time to rebuild the rear shocks but went with 30wt, #2 pistons, 2 limiters, Avid whites, 1/2oz in the rear triangles, and 1/2oz under the receiver as well. Rear bite didnt change much but I lost some steering (wanted to pull the weights out of the triangles after the warm up laps but didnt have a chance to do it. For the main, I tried the Avid yellows out back and removed the weight from under the receiver. Car felt pretty good all the way around (could use a touch more steering) but is very stable and I was able to brake pretty heavy without having the rear come around (much more so than in the past). I shaved the u-brace but didnt have a chance to install it or the C mounts and I still need to install the B44 rear arms to complete the setup to test for next week. I'm planning on trying 1/4oz in each rear triangle next week with the yellows and will also try no weights with the white springs. Shaved .7 seconds from last weeks setup and .4 from my fastest ever on this layout (was running the TLR22). Going the right direction but I need to shave 1 more second to get on pace with the fast guys.
Oh, installed the XFactory topshaft, JConcepts silent series spur, and installed a new pinion (Robinson) to address the noisy trans issue I was having and I'm happy to report that it is almost silent now, huge difference! Replaced the topshaft bearings as well (Proteks). Picked up a new idler gear but they were out of diff gears. I'll install both when they arrive and I'm fairly certain the noise issue will be completely gone. Let my buddy drive the car after the race; Track 1, front hex axle 0! http://i779.photobucket.com/albums/y...azl/IMG135.jpg |
Originally Posted by stang
(Post 10755430)
or $209.99 if you can get people to give up the codes. cause we all know people love to give them up
http://www.rctech.net/forum/electric...n-codes-3.html |
What do people mean by C mounts?
Originally Posted by SoccerSting
(Post 10755596)
Originally Posted by chancejeff
(Post 10754388)
I have a problem it's like my car doesn't want to go off the start but once it gets going it is good. It only happens when on the track I can hold it up and it will start up perfectly no delay. I was thinking it was my new tekin setup but it's fine when I hold it in the air and gas it. Also maybe because my wheels rounded a little on the hex part but than why would it be fine when it gets going. I was thinking the slipper pads also but why would it be fine when it gets going. Idk I'm lost. Any help would be appreciated.
Originally Posted by Jmuck69
(Post 10753891)
Did you notice the JC branded thumbscrews on the lipo strap.
Originally Posted by elex300
(Post 10755789)
The aluminum rack is supposed to be lighter than the Avid rack.
Originally Posted by Kyle Wilson
(Post 10755841)
Really?!?! The AVID unit is 3g heavier than stock and with some of us adding additional weight to the nose, the extra weight is a godsend!
Originally Posted by B00t13g
(Post 10755846)
Agreed, I've added 5g on top of an aluminum pivot and 5g in each of the front triangles.
Well
i ran my buggy with the avid and they are awsome i started out with two's and 32.5 and reds all arond then went to two's and 30 and yellows all around and it it was much better cant wait to get them for my truck |
(Post 10754975)
So I guess im gonna fold under peer preasure:lol: and see how the Losi BB springs work. I run brown/green 30/27.5(Losi) and a full stick pack currently. The track is medium to high bite clay. From what I gather from you guys I should start with yellow rears and orange fronts? Im gonna order wht and yellow rears and red and orange fronts to give myself some tunning options but this is a good starting point correct?
whats the part number for trhe xfactory top shaft and where did u get it? its funny you mentioned it as i was just going through my transmission ans noticed that whenever you adjust the slipper it preeses on the bearing race which inturn is pushing the spacer over and then the gear is lightly rubbing the opposite side tranny case, or just binding slightly on the bearing and making the gears not stay riding 100% true
Top shaft
Originally Posted by eper
(Post 10756706)
In order to use the BB springs I need the traxxas collars and 22 cups correct? I know other companies make these but in general this will work?
| All times are GMT -7. It is currently 09:11 PM. |
