RC10B4.1 FT/WC
Old 02-02-2012 | 08:14 PM
  #10846
B.A. Racer's Avatar
Originally Posted by mxracer458
Did you dip them when they were still blue?
yes just polished them up a bit
B.A. Racer is offline
Old 02-02-2012 | 08:30 PM
  #10847
Tyler Keel's Avatar
I would have probably stripped the blue anodizing off before, might have got a little better result although they do look good. When I did mine years ago on my Losi cars I just always had a perfect lunsford polished one to go with.
Tyler Keel is offline
Old 02-02-2012 | 08:33 PM
  #10848
What size hex do I need for the front wheels! Thanks
bigdog is offline
Old 02-02-2012 | 08:48 PM
  #10849
mxracer458's Avatar
Is a 122oz servo good for two wheel
Buggy?
mxracer458 is offline
Old 02-02-2012 | 09:22 PM
  #10850
DoubleRJef's Avatar
Is anyone running a spacer of sort on the front FT axel? I have some slop on the front wheels even when the screws are tight.
DoubleRJef is offline
Old 02-02-2012 | 09:25 PM
  #10851
Odin544's Avatar
Buggy?
thats plenty.
Odin544 is offline
Old 02-02-2012 | 09:30 PM
  #10852
Tyler Keel's Avatar
Make sure your bearings are seated fully inside your rims...if they are and you still have slop...welcome to the AE B4.1.
Old 02-02-2012 | 09:32 PM
  #10853
DaveW's Avatar
Originally Posted by T-BirdJunkie
Yeah, it helps spread out the load from the screw holding stuff down...but on the shock towers the benefit is limited, at best.
Is this a proven fact by ThunderBirdJunkie?
Sorry... you forgot the third person stuff i look forward to each day.
DaveW is offline
Old 02-02-2012 | 09:39 PM
  #10854
more slop = more gooder
Bob Barry is offline
  #10855
racer1812's Avatar
Super Moderator
Originally Posted by mellow
There was a running change on all new towers. The outer hole was removed and a third hole was added on the inside.
..beat me to it matt
Just to clarify because some may not have followed this thread forever and the above can be a little misleading....They only moved the inner hole on the B4.1 tower...4th hole location on a T4.1 or SC10 would still need to be drilled.
racer1812 is offline
Old 02-02-2012 | 10:04 PM
  #10856
1mrdad's Avatar
I use these http://www.amainhobbies.com/product_...-3-16-Shims-14 on the front axles.
1mrdad is offline
Old 02-03-2012 | 06:11 AM
  #10857
Asharus's Avatar
pretty disappointed with my worlds kit. one of the rear u-brace ballstuds does not have a hex head on it (just round) so I can't even drive it into the brace, and the shocks are not smooth inside
i've emailed AE and will probably get replacements soon, but I was hoping to run a new kit this weekend.
http://imageshack.us/photo/my-images/19/img0245go.jpg/
Asharus is offline
Old 02-03-2012 | 06:55 AM
  #10858
To lessen the slop in the front end of my AE cars that run the bearings on the wheels, I take an orange shock O-ring and put it behind the wheel nut. When you tighten it down it snugs up the slop without causing any bind. Be careful not to tighten it too much as it will flatten out and rub the inner and outer race of the bearing and cause drag.
monkey-1 is offline
Old 02-03-2012 | 07:05 AM
  #10859
for those of you waiting on GHEA... I will not be receiving it until Monday by 10:30am EST... At that time i will stop what i am doing and list the items on our site. I apologize to you who were hoping we would have it today... Thank you for your patience...
Chad Phillips is offline
Old 02-03-2012 | 07:25 AM
  #10860
Matt Ward's Avatar
I tried running a spacer to take out the slop but I didnt like it. Try it once and see if you do. Its all about preference.
Matt Ward is offline
