RC10B4.1 FT/WC
Old 12-07-2011 | 10:44 PM
  #8266
Guest
Originally Posted by LOSIRACER77
r u a team driver?? who r u ??
and will the new car come with the hex rims?????
LOSIRACER77 is offline
Old 12-07-2011 | 11:04 PM
  #8267
Teambcw's Avatar
not a team driver, just know too much.....
Teambcw is offline
Old 12-07-2011 | 11:09 PM
  #8268
Guest
do u know if the big bores are the same size as the 4x4 corr truck??
Old 12-07-2011 | 11:11 PM
  #8269
Teambcw's Avatar
they are not even close to final...
Teambcw is offline
Old 12-07-2011 | 11:14 PM
  #8270
Guest
ok i got u,
  #8271
jirish617's Avatar
need a little help guys...
first...my dogbone keeps popping out, and its not on a jump or a crash, happened 3 times today...it doesn't seem to be bent, and when it is in place it doesn't seem like it could even pop out just by looking at it... I have 2* camber, which should have the dogbone closer to the diff. i dont have the SLIGHTEST clue that would cause it...
now my next issue... the car seems like its top speed is either their or not...one lap the car seems to scoot, the next the car seems to be dragging ass...I did put a new sensor wire on because the others were shorter, and kept falling out, but this one hasnt...but when the speed is low it seems similar to when the sensor wire is unplugged. I'll have a few quick laps right off the bat, then the cars speed seems to slow down for the rest of the time...possible my slipper or diff is too tight?
sorry for the dumb questions, still learning.
jirish617 is offline
Old 12-07-2011 | 11:18 PM
  #8272
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
How many limiters do you have in your rear shocks? On most AE cars, if you have no limiters in the rear shocks, you will have this problem.
T-BirdJunkie is offline
Old 12-07-2011 | 11:24 PM
  #8273
jirish617's Avatar
i got 2 in the rear, i used the Paul Wynn setup for reference and made some of my changes accordingly...
I have used this setup for about 5 or 6 track days and it just started happening tonight...
Old 12-07-2011 | 11:25 PM
  #8274
Guest
do u have a novak motor??? if so u could have a bad sensor??
Old 12-07-2011 | 11:26 PM
  #8275
Is it possible that you've got a cracked T-plate or arm mount? What all have you checked?
Old 12-07-2011 | 11:39 PM
  #8276
jirish617's Avatar
well i figured it out... the inside bearing on my rear hub was...blown out you could say?
heres what was left of it...
idk if any of you would know, because i bought the car used and it has the b44 hubs...i know the outside bearing is larger, but is the inside bearing a different size than the ones for the normal rear hubs?
Could this explain why it seemed sometimes the speed of my car was quick and other times slow?
Old 12-07-2011 | 11:46 PM
  #8277
pic omitted
You found the solution to all of your problems.
Inside bearing is 3/16x3/8 just like the front wheels and the transmission, so if you've got spares, you're good to go
Old 12-07-2011 | 11:50 PM
  #8278
jirish617's Avatar
thanks for the help! Explains why my motor, motor plate, slipper felt pretty d@mn hot after each run today... and explains why my car sounded extremely abnormal to me throughout the night as well.
my only other question is, because i ran it for 2-6 min qualifiers, a main, and about an hour and half of practice...do I have to worry about damage to other parts being done due to the abuse/lack of a bearing?
Old 12-07-2011 | 11:57 PM
  #8279
BIG RE's Avatar
Originally Posted by nick the quick
Man Pudge's car is working really good today thanks for leaving it Ryan
I'm believing in the conspiracy theory here, that M11 is in standard "righty" configuration, Cavaleiri is a lefty....
BIG RE is offline
Old 12-08-2011 | 03:35 AM
  #8280
Jason Haas's Avatar
Originally Posted by idrummerboy13
I ran jason haase's setup he posted recently and it actually is really nice, I think a 2.5 toe in block would be a little faster in the times
I will try the brent theikie grand prix setup now i will post results
the setup was pretty consistant but it was more of you had to push the car hard or drive smooth but that could be a number of factors
I do runa 2.5 toe block Outdoors and on higher bite tracks. Bumps and jumps drys out at the end of the day so that's why I have A 3.0 block in
Jason Haas is offline
