RC10B4.1 FT/WC
Old 02-05-2013 | 06:45 AM
  #27961
Originally Posted by sneako
Yeah, it's like when people use "4" instead of spelling out FOR or using "U" instead of...oh wait, never mind.
That's right. More mature people would call that car a Bfor.
kevinrc is offline
Old 02-05-2013 | 07:23 AM
  #27962
Originally Posted by Wildcat1971
I thought for sure you were 14-15........darn internet
Same Good job with your build Vito.
Kuya_Kimo is offline
Old 02-05-2013 | 07:42 AM
  #27963
vito's Avatar
look at my pic of the esc wires to motor . it to short how to make them longer my lhs dose not like to heat up the bord on the esc.
vito is offline
Old 02-05-2013 | 07:48 AM
  #27964
vito's Avatar
you guys are lucky i dont have kids
vito is offline
Old 02-05-2013 | 08:00 AM
  #27965
Wildcat1971's Avatar
that just means more money to spend on hobbies.
Wildcat1971 is offline
Old 02-05-2013 | 08:06 AM
  #27966
vito's Avatar
this is whats in the car esc is a novak gbt2 lp with 8.5 motor rx is a sr 300. tires are panther slicks clay front and rear. slipper is a avid 81 kit. hexs allround. pack is a 30c 5000 mh 2s.
vito is offline
Old 02-05-2013 | 08:07 AM
  #27967
MikeXray's Avatar
How do you think the wires got attached to the board in the first place?
Everyone replaces wires from the board, get a good iron that can get over 700dg with a good tip (not a pencil style), tin the iron and touch the solder joint and it should release very quickly. If you have to leave the iron on it for a more than a few seconds, stop, let it cool, then try again.
MikeXray is offline
Old 02-05-2013 | 08:08 AM
  #27968
2canSAM's Avatar
R/C Tech Elite Member
Starting to do some experimenting with foams. Are Open Cells still the go to foam for bumpy tracks? Also when do you call the track bumpy? Our track is hard packed clay with some small maybe 1-2" rutting sporadically throughout. The link to our track is in my signature.
2canSAM is offline
Old 02-05-2013 | 08:14 AM
  #27969
vito's Avatar
will the panther sliks do ok in the street and last long?
vito is offline
Old 02-05-2013 | 08:57 AM
  #27970
Originally Posted by LOSI123
Can anyone help me with how to buy the spacer that goes behind the caster blocks on the hinge pin?
Manual says 7922 but that is the 30deg C-hub and when I brought some there was no spacers in the packet
just use the aluminum ball stud washers. I forget my exact setup but I think it was like 1 2mm blue washer and 1 .030 silver and that took out all the slop. I'll try to remember to look for you tonight and snap a pic of it.
Bob Barry is offline
Old 02-05-2013 | 08:59 AM
  #27971
I only use closed cell in the rear but I'm switching back to open cell fronts. Closed cell fronts make my car steer like it's got an eight foot plow on it.
Old 02-05-2013 | 09:14 AM
  #27972
sunco1's Avatar
That's been my experience to. I run opens in the front and I usually trim the inner and outer edges a little bit.
sunco1 is offline
Old 02-05-2013 | 09:39 AM
  #27973
2canSAM's Avatar
Thanks guys. I meant rear. I did not like CC foams up front at all. I appreciate the responses.
2canSAM is offline
Old 02-05-2013 | 09:52 AM
  #27974
Razathorn's Avatar
Does that equate to a lot of steering or little steering. Honest question. I don't know how a plow drives.
Razathorn is offline
Old 02-05-2013 | 11:44 AM
  #27975
Waflet's Avatar
Hideeho
Last layout I tried open cell stock vs proline v2 vs aka red. All were in green dd's mounted on rulux wheels. Neither of the closed cells worked at all. I tested them back to back on the same day with a full pack each. The stock open cell worked MUCH better. That said our current lay out is MUCH softer with rounded bumps rather than sharp edges. The current lay out is much bumpier but the bumps are more rounded, so it might be worth testing again. Let me know how it goes.
Waflet is offline
