RC10B4.1 FT/WC
like I said, I plan to play with tires first. I like the way it feels in the corners. I just have issue getting on the power exiting. I have a few other issues to work out also since getting the BB shocks. Jumping is inconsistent for one. My list of likes and dislikes is about even right now, just trying to get more like in the like column.
I got in my big bore pistons. excited to see how they work in comparison to the kyosho's already in the shocks.
Anyone have any tips I should keep in mind when putting in the pistons? figured I ask now and get the info right away.
Wild , making the jumps is more a skill or driving issue then set-up .
One thing I advise to anyone ...
Do not try tune your ride just for the jump.....
Tip
The slipper has a bigger effect on jumps them most anything else .
In Stock ?
Some may not clear the jump and wish to blame many things .
Like , motor , gearing , set-up...
I usually love those ..
Because all I have to do is set the slipper correct and all the sudden they clear jumps that they were having difficulties with...
Most I find have the slipper way to tight or needs cleaning ...
Tip
In Stock ?
Getting ready for our N/w ShowDown tour @ Trcr this week end ..
So when I rebuilt the gear box yesterday ?
I got to inspect the slipper pads on my AVID Traid.
After all that wear & tear ?
The pads still look almost new , no glaze ...
Also never had to adjust the slipper unless traction also changed .
The Triad stayed consistent and reliable the whole time ...
Very impressed ...
Very impressed ...
Tip
In Stock ?
Tip
In Stock ?
your setup sheet says low traction. If you indeed have low traction, did you try the A Hubs? Not sure i would go with heavier oil. I would try the green rears first. A few people have posted that the whites in the rear were a bit twitchy. I gained a bunch of steering with my BB shocks also. But, I am dealing with fish tailing on power. If my new rear tires dont help, then I might need to play with my camber links.
If your car feels good in the corners, but you're fishtailing on power, you want more weight transfer to the rear. Softer spring in the rear, remove weight up front, move the battery back, decrease camber, and increasing droop up front will give you more rear traction. I've gone back and forth between the A and C hub, and I still continue to do so. The A hubs will hang on longer in a turn, but are harder to correct if I come in too hot. I'll spend some time getting it dialed in today.
edit: As WC said, don't add/shift weight to help with flight. If the car is doing squirrely things in the air, check droop, check for binding, and learn how to adjust your car in air (using throttle/brake/steering). Letting off on the face of the jump will make the car nose down as well.
Even if the car is correct & perfect...
If a driver hits a jump to fast , has power on before the square up facing the jump ?
Back end will slap , car noses up , barrel rolls, ect ...
i got my 2 lrp's back this week as well.
boy, i wish i could have spent 3 months in southern california!
great commentary on the slipper, dont forget when your car lands and is squirrely that usually is a sign of a slipper that is too tight
@wc that could be true. Like i said, I am driving the same, just changed the shocks. I would think that the additional pack of the 1.6's, I would have less slap on the jumps than my v2's.
