RC10B4.1 FT/WC
Old 12-28-2012 | 07:52 AM
  #26356
Scrubb's Avatar
Originally Posted by mashimarowu
Does anyone know how to fix the steering when you turn one direction and your servo is pushing in that direction, but when you throttling through a turn you push wide until you slow down to turn the direction you want? I always see my servo trying to push my wheels the right direction, but it seems like its not getting enough power and is letting go. Not exactly sure how to explain it, but I hope that is enough. I already have the avid steering block and aluminum horn if that matters.
Its sounds like your your front tires are touching part of the front suspension and are locking up. Set your car on a car stand, free spin the front tires, and turn the front tires left and right with your controller. Are the tires rubbing on the suspension causing them to lock up? If they are, something is assembled incorrectly (I would check and make sure the black plastic spacer is correctly behind the castor blocks - a common mistake that would cause that, the second is that the left and right castor blocks are on the wrong sides).
Scrubb is offline
Old 12-28-2012 | 07:57 AM
  #26357
I was wondering what motor you guys are using for mod buggy? I have been out of the whole electric game for the last five years or so since brushless and lipo packs have really came into the scene. Any help would be appreciated. Oh and I am using the new lrp flow esc.
Jmnay_83 is offline
Old 12-28-2012 | 08:04 AM
  #26358
YankeeFan123's Avatar
I'm running a Reedy Sonic 7.5 with an LRP Esc with the updated board
YankeeFan123 is offline
Old 12-28-2012 | 08:10 AM
  #26359
'im run 8.5 or 10.5 depending on the layout and amount of traction there is on the track.
micrors4guy is offline
Old 12-28-2012 | 08:22 AM
  #26360
Cain's Avatar
Tech Legend
looking to use an 8.5 Speed Passion here since its full mod.
Cain is offline
Old 12-28-2012 | 08:26 AM
  #26361
t0p_sh0tta's Avatar
Depends on the size of the track really. I was running a boosted 8.5 previously, but recently went with a boosted 9.5. The Orion motor didn't have the torque that I was looking for. I'm much happier with the Gen 2 Tekin that replaced it.
That said, A blinky 13.5 would get the job done most of the places that I run.
t0p_sh0tta is offline
Old 12-28-2012 | 08:29 AM
  #26362
Cain's Avatar
Tech Legend
If the motors had the torque, I'd say on the track I plan to run on a 13.5 or even 17.5 would be plenty, just need the torque. But some of the guys run even 4 pole SCT 4x4 motors.
Cain is offline
Old 12-28-2012 | 08:37 AM
  #26363
Most of the tracks in the Midwest are indoor high bite clay. So that is what I will be running most of the time. When I was racing a lot before my wife and kids came along I almost always ran reedy 12 turn double geared 81 21 if I remember right. So basically I just want something comparable to that. Thanks again for the help.
Jmnay_83 is offline
Old 12-28-2012 | 08:45 AM
  #26364
t0p_sh0tta's Avatar
7.5 - 8.5 will fit the bill then.
Old 12-28-2012 | 09:15 AM
  #26365
huzzler's Avatar
Most people I know that run mod use a 8.5. You can always turn power down on esc if it is to much.
huzzler is offline
Old 12-28-2012 | 09:41 AM
  #26366
yup pretty much.
I just ordered 7.5 and 8.5 for SC and buggy respectively. If I need more than that, I may as well just give up LOL
Bob Barry is offline
Old 12-28-2012 | 09:43 AM
  #26367
njnewc's Avatar
I run a 10.5 tekin motor. Not the fastest by any means but there is nothing I cannot clear. It's real tame and controllable. I had a 6.5 but that was too much.
njnewc is offline
Old 12-28-2012 | 09:47 AM
  #26368
Wildcat1971's Avatar
Originally Posted by zipperfoot
Really? The big bores weigh that much more that you can take weight off? Isnt weight added to balance the car front to rear and side to side?
I think I read it it like 16 grams total added
Wildcat1971 is offline
Old 12-28-2012 | 10:05 AM
  #26369
idrummerboy13's Avatar
I had my orion 7.5 in and it had very little punch. I threw my 10.5 back in and got more low end and more control. Suddenly I was pulling very fast laps, I just need to get to the track on a more consistant basis...but dont we all
I was using green slicks and boy I couldnt stop the wheelies. I am going to try and loosen up my car...
idrummerboy13 is offline
Old 12-28-2012 | 10:11 AM
  #26370
huzzler's Avatar
Just wondering,you guys running the shorty packs in 17.5 class. Do you leave the weights in the rear? I run full packs now and I have ballast weight and 1/4 oz each rear triangle. I have tried removing the weights and the car just loses alot of traction. So I guess what I'm trying to say is the whole point of running the shorty is to reduce weight and improve handling right? So to me it wouldn't make sense to run the shorty without weights. As far as handling with the shorties,I don't think I can get my buggy to handle any better than it is now its awesome. Guess I should maybe try and borrow one and try for myself.
huzzler is offline
