Kyosho Ultima SC-R Thread
#4308
Moderator
Trader Rating: 470 (100%+)
A shadow means a truck is coming.....lol
#4309
Moderator
It would be great if the wheels drop right on. I have lots of wheels and tires
#4310
What track do you go to qdrhrse?
#4311
Our track runs 17.5 boosted for "stock" class. I am getting killed on speed. Currently running orion esc with a ion4 17.5 boosted 40 deg. It is slow and has heat problems. Anyone out there have a suggestion of what to try. I have gone from big spur/small pinion to small spur/big pinion and cannot find speed.
Thinking of going back to Tekin RS and Gen2 17.5???
Turbo
Turbo
#4312
What is your gearing? Are you geared for the track. You need to find the right gear ratio for your track before you add boost and timing. For my rt5 i ran 75/26 for 17.5 in blinky, then i would slowly add timing on the can, when i got that worked out i would add boost thru the speedo. You might have go down on your pinion a tooth or two depending on how hot the motor gets after a few minutes.
#4313
#4314
Having owned a FT SC10 and now a SC-R they are both great trucks. Most guys around me are running SC-Rs and not SPs or big bores and they are plenty fast.
New releases will always happen. You could always wait (indefinitely) until a new Kyosho comes out and everyone will fire sale their SC-Rs and SP LOL
#4318
Moderator
I have at least one maybe two of the blue machined strc motor plates as well as the aluminum hinge pins hangers and lots of other scr goodies that I do not need like diggity designs carbon shock towers and carbon battery strap and kyosho blue battery thumb screws/tower.
Matt
