Durango DEX210 Thread
Tresrey clamping hex, i found with threadlock it made it very hard to get the pin out when i needed to, exotek hex is ok but the grub screw pushs the pin out abit
Location: Norwood, OH...and CCRCR and The OhioRCFactory
x3 on threadlock
I used the Exotek hexes and they were trash, that setscrew is so far off center it's not even funny.
Or you can do like I did & put on 12mm clamping hexes & run the same wheels as everyone else at the track (notice the other 1/10 car I drive ).
P.s. It's kinda weird not seeing you talk in 3rd person
And yeah, I gave up on it. Too many keystrokes :P
B5 front axels work on our cars? I've been debating 12mm hex on my 210
What changes can I make to gain forward bite ?in the rear I'm running 3x1.6 pistons, 30wt oil, light blue spring , low roll center blocks , 3deg antisquat. Where should I start?
tires and less rear camber are the first things I'd try
Oh yah forgot tires, I'm running pro-line pinpoints ( I race on carpet) , camber is at -1 degree
depending on your front end setup, more front droop can help but can lead to traction roll in high grip situations, like carpet. try playing with you ride height (lower rear or higher front), but dont forget to reset your camber after a ride height change. what inserts are you running in your tires? open cell can allow more ballooning which gives less traction after the corner as you accelerate away. i dont know what your skill level is or what your driving style is, but being less aggressive on the throttle is the absolute best way (assuming the rest of your setup works well for you). im not talking a big change, just a fraction slower (.5 seconds to go from off throttle to full instead of .1 second).
did you mean the 3deg RF mount or 3deg antisquat, if you're using the 3deg FR mount I would try going to the 0deg one.
Anybody experience the driveshaft popping out of the balldiff outdrives after a bad landing, its getting very annoying the driveshafts should be longer, damn you durango
