Durango DEX210 Thread >
Like Tree80Likes
Old 10-24-2011, 02:14 PM
  #1111
Konich's Avatar
Behind the servo to keep as much weight "inline" as possible
Konich is offline
Old 10-24-2011, 02:15 PM
  #1112
Not a bad idea. I'm running MM4 config and prob ditching my SP ESC for an Orion R10
mikeyscott is offline
Old 10-24-2011, 02:44 PM
  #1113
Finding no matter how I set the slipper it slips. I can turn the spur by hand
Old 10-24-2011, 02:53 PM
  #1114
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Is it built correctly? Tighten it? Take a pic...
Cpt.America is offline
Old 10-24-2011, 03:02 PM
  #1115
grapejuice's Avatar
Trader Rating: 152 (100%+)
You should be able to turn it by hand...have you driven it?
grapejuice is offline
Old 10-24-2011, 03:04 PM
  #1116
scr8pn4205's Avatar
To all with the diff issues on the 210. Have u measured your thrust washers? One is smaller diameter than the other. The smaller one goes in the out drive with the groove facing diff gear then the caged washer then the larger thrust washer with groove facing the caged thrust balls. I just helped a friend build his first ball diff and it turned out like butter. Might have to sell the 22 after looking at his car. For the slipper issues make sure you cleaned the slipper hubs with motor spray as any oil on them will let it slip. If they have slipped a lot you can sand lightly the slipper pads with 400 grit sandpaper to get rid of the glazing and reassemble.
scr8pn4205 is offline
Old 10-24-2011, 03:46 PM
  #1117
Hi
Many thanks.
Mike
Old 10-24-2011, 03:48 PM
  #1118
I agree with that, just a question of how easily it turns.
No not yet no electrics in and shell at Jon Miller's
Old 10-24-2011, 04:35 PM
  #1119
1armed1's Avatar
Trader Rating: 79 (100%+)
I made it to the track Saturday,had a quick club race then practiced for about 10 hours.I can easily say I'm happy about the car change I made.
The only issue I had was the ballcups but that is now sorted out using Kyosho studs and cups.
I still have a few tweaks I want to try but the car is really good as it sits now.
The track was medium grip clay and I had all the traction I needed even when the track was dry.
The car would just squat and launch out of the corner.
High speed steering was smooth and plentiful, low speed steering was crazy.
The car was very smooth and stable, easy to push it hard and not get out of shape.
My set up
Front
1.2x4 ae 30 wt
Stock spring, shock mounted in and in.
Stock camber link locations and ball stud height.
Spindle height centered, block forward and axle 4mm trailing.
20* Caster
Rear
1.3x3 ae 25
Losi Pink Spring, shock mounted in on top and center on arm.
2mm under inner camber ball stud and outer in location #2
1.5* Anti squat
3.5* Toe in
Hubs forward
Battery back
Weight added
21g each rear corner
14g at both front corners of the battery
Tekin Rs/8.5 combo
Dayton
1armed1 is offline
Old 10-24-2011, 05:20 PM
  #1120
Just found out I need a 3mm nut driver bummer, don't have one
JayBuc is offline
Old 10-24-2011, 05:32 PM
  #1121
Or is it a 5.0mm outside diameter that fits a 3.0mm nut?
JayBuc is offline
Old 10-24-2011, 05:41 PM
  #1122
teeforb's Avatar
Trader Rating: 94 (100%+)
can you comment on the 20* caster and 1.5 kick up? Do you get a lot of steering with the 20* caster and how is you rear traction with the 1.5kickup?
My set up
Front
1.2x4 ae 30 wt
20* Caster
Rear
1.3x3 ae 25
1.5* Anti squat
3.5* Toe in
Hubs forward
Battery back
Weight added
Tekin Rs/8.5 combo
Dayton
teeforb is offline
Old 10-24-2011, 05:53 PM
  #1123
1armed1's Avatar
You need a 5.5 mm nut driver.
1armed1 is offline
Old 10-24-2011, 05:57 PM
  #1124
1armed1's Avatar
The 20* is a bit smoother at high speeds and aggressive at low speeds.
Traction was not an issue at 1.5* anti squat.
1armed1 is offline
  #1125
ABBOTT's Avatar
Which fits the 3mm nut
ABBOTT is offline
