Durango DEX210 Thread
Hi there. Has anyone try a associated ball diff on their dex210?
The dex210 ball diff slip too fast. I want to drive it loose like i did it with the b4.
With a 10,5- 17,5 motor the diff dont slip but with ny 7,5 turn engine it slips too fast comared with te associated and rb6 ball diff
Mihael
Mihael
I ordered all the parts friday. I did a similar mod to my 22. Worked out great. Thanks guys
You might want to check your diff dude the ball biff in my 210 is like butter. Its actually one of the reasons i bought the kit.
Hi
Yes it's like butter but it slip too fast if it isn't so tight.
The b4 ball diff i can run more loose without slipping.
I just want to know if its possible to make the associated ball diff fit.
Thank you
Thank you
Got ya...i cant relate i run diffs pretty tight our track surface is like blacktop
i have the sc10 gear diff in mine it had to be shimmed it came with the used dex210 and my ball diff was horrible so i haven't switched back yet even tho i rebuilt it i like the ease of the gear diff
has anyone have problems with the ball diff where the nut backs off during a run. if anyone has any ways to fix that.
dab 'o loctite
If the nut is stripped or worn id replace it.
Oh and i meant the diff not the nut being in backwards. Just to clarify.
the diff screw is on the oppisite side of the slipper nut or it will come loose.i have no problems with mine.no loctight.
