Durango DEX210 Thread >
Like Tree80Likes
Old 02-21-2013, 06:29 PM
  #10336
Trader Rating: 29 (100%+)
Originally Posted by the big rc
no luck searched ebay and nothing im after part LXCBZN
You are looking for this part# TD330339 the one you posted is Towers internal number.
Walkman is offline
Old 02-21-2013, 06:40 PM
  #10337
the big rc's Avatar
Trader Rating: 40 (100%+)
searched that too and got nothing
the big rc is offline
Old 02-21-2013, 09:06 PM
  #10338
singlemike's Avatar
Big Rc-
Send me a pm- I just replaced the right knuckle so I have a left (driver's side) that I can send you.
mike
singlemike is offline
Old 02-22-2013, 01:06 AM
  #10339
Originally Posted by glenng
for starters, what type of battery do you have and where is its placement on the chassis? do you have a 30g mass under servo like ryan lutz does in his wcrc setups as well? if not (in conjunction with your battery placement), you might be lacking front-end weight which could cause your pushing.
I have 2 three year old thunder power 5200 mag 100c from back in my 4x4 sc days but they are getting retired tomorrow. I currently run my batter as far up towards the servo as that little stop will let me, I put the ounce of weight on the front and it made a huge difference Corning but not Corning under power, when under the slightest amount of power it just loves to push,
Originally Posted by 8ight-e
Here is my clay very dialed, but as mentioned battery placement and the front weight are key ingredients.
Sweet thanks man we have very similar set ups just your shock oil weights are heavier and springs are different. I will try your set up tomorrow.
And another question. All the guys running 17.5 motors are just as fast if not faster then my 13.5? I'm running a 75/27 I'm new to this whole book of Rc secrets and have no clue how there's are so quick. I'm getting a new battery tomorrow hopefully that will help.
Bingerfang is offline
Old 02-22-2013, 02:45 AM
  #10340
Trader Rating: 16 (100%+)
The 17.5 guys you are driving with most likely have the boost, turbo, and timing cranked up on their esc. That and taller gearing could easily put them in 13.5 territory. You could always do the same if it's an issue for you. The 17.5 guys are most likely running a lot hotter than you are, which can shorten the lifespan of their electronics. A fresh battery is great but there is more to it than that.
zipperfoot is offline
Old 02-22-2013, 10:32 AM
  #10341
petite rc hooked me up with some setup sheets for the tekin rs pro for the boost and timing and all those goodies so hopefully i can try that and keep checking the motor temps and go from there. the car still pushes underpower more power= more push for my setup ahaha
Old 02-22-2013, 11:31 AM
  #10342
SKIMAN's Avatar
Trader Rating: 17 (95%+)
Default chassis
I know this question has been asked before, but im looking for some input on what the difference in chassis's has been on high bite surfaces..the +8 compared to the normal alum chassis..Thanks
SKIMAN is offline
Old 02-22-2013, 12:02 PM
  #10343
From what I have read you said that you have your battery mounted forward and you have weight over the front, and you are still pushing? Something else must be going on. How about tire selection. The only time my buggy ever gives the slightest hint of pushing is when I use the wrong tires for the track.
If the tires are good, then I would guess the gear diff. I believe someone with more experience than I provided you with some info about what to run in the diff. Springs, pistons, and oil would be the next thing I would check.
Old 02-22-2013, 05:26 PM
  #10344
Hay guys my track just received a shipment of Steering knuckle and hub sets. 4 to be exact and I was able to grab 2 of them I need 1 and I will sell the extra one if anyone still needs them. I'm at the track tonight and won't be home until late.
Already sold. I will let you guys know if my track gets any more in.
Walkman is offline
Old 02-22-2013, 10:02 PM
  #10345
P6
hows everyone fixing their (on power push) my buggy feels very balanced with 22-23mm ride height drk green front spring pink losi in rear spring 3m trailing i noticed most use the longest front camber link they can i found using the inner hole on the c hub gave me the mid corner on power steering i wanted ,, maybe drk blue rear spring to help the transfer to the rear? ,, ive tried putting my battery full forward but then had no rear corner traction and to much steering
P6 is offline
Old 02-23-2013, 06:22 AM
  #10346
tedstryker's Avatar
Trader Rating: 88 (100%+)
Just wanna share my experience with RW Racing Spur .....
Horrible it lasted 1 QUALIFIER..
Funny thing after looking everything over I noticed center hole on the spur was the size of a dime....reason I got RW nobody had any spur's in stock. 4 People at the race wow RW? ..Yup...
Put the Durango spur back on not exactly the gearing I wanted but hey ...not one issue...all weekend...
tedstryker is offline
Old 02-23-2013, 06:38 AM
  #10347
Trader Rating: 79 (99%+)
Ted,
I have the same RW 83t spurs in both buggies for over a year now. As of matter of fact, I just replaced my pinion gear. It was very worn out. The spurs are still being used.
Raul Garcia is offline
Old 02-23-2013, 06:52 AM
  #10348
tedstryker's Avatar
Originally Posted by Raul Garcia
Ted,
You're lucky I guess....
Old 02-23-2013, 07:07 AM
  #10349
OSherman's Avatar
yeah, that must have been a fluke incident.. RWs are great.. been using them in my SEDANs and now my BUGGY.. no issues here..
OSherman is offline
Old 02-23-2013, 07:09 AM
  #10350
Ted,
Yup, me too. Same 69 RW spur for four months, with a 13.5, and then 17.5. No issues still looks fresh. As a matter of fact, I am still running the original ball diff. Still smooth.
