Durango DEX210 Thread
#8986
Hey guys just ordered one of these buggies. What should i know or do while building the kit right away. Also does anyone know a good starting setup for a high bite carpet track??? Also how is the quality of the tresrey option parts. Looking at picking some parts up from them. Thanks for any input.
#8987
Watch the video about building the ball diff. Almost noone gets it right the first time.
Otherwise, it's pretty good out of the box. Take a look at some of the setups on Durango's website.
On a carpet track, you'll definitely want to go with a MM (Mid-motor) setup - probably the MM3.
Tresrey parts are good, but I prefer the Exotek parts - I like to stay with the factory gold and their parts are par-none for quality!
http://www.exotekracing.com/durango/
#8988
Read about the ballcups. I don't recommend boiling them - but tap'ing them out and greasing them.
+1 on balldiff. I think you would want to tighten it tighter than you think. On carpet, I've found mine to slip quite a bit and ended up tightening and retightening, etc... until I finally said screw this and got a gear diff.
MM4 for carpet. There is less grip with the MM3.
#8989
+1 on not boiling the cups...that's a stupid idea (my opinion). OR you could just jump the gun and get the associated ballcups mod (search within this thread).
Still loads of traction
Schumacher mini pins are great rear tires on carpet
#8990
For those running on carpet have a look here on petitrc for setups.
I started with David Poulters Irish outdoors astro setup and went from there. OR try this setup from Jörn they are different as running the 210 has progressed but the DP setup is my start setup as I know its easy to drive.
Change oils/springs to your track
Tyres:
Run minipins if you can and are allowed at the club otherwise panther clays (which you should beable to get locally) or VBC slicks from sweden (or me) with addative works well and doesn't take such a toll on the carpet after prolonged driving.
For more indoor setups have a look on oOple TD BIT the Uk version of this forum, there they run indoors a lot over winter
Tyres:
#8991
I have my shorty pack all the way forward against the front battery stop and a foam spacer in the rear. Tonight i started to push the buggy a little harder than usual and noticed the rear felt a little light. Shocks and springs are perfect, and tire selection was right on, so in my opinion the battery needs to be adjusted. I do have a 1/4 oz of weight up against the tranny in the battery tray. Where are you guys placing your battery and are you using weight?
#8993
#8994
Our local carpet track was turned into an indoor clay facility, so I bought the 210. I have absolutely hated this car ever since the first day that it hit the track. Unreal push off power, ridiculously loose on power. Absolute garbage. The fastest guy on the track is running the 210 and I'm not one to give up just because the kit setup doesn't work. I started with MM3 and all kinds of shock positions, oil weights, added weight, tires, bodies, etc. Car didn't work. Went to RM3 and started over again. Car was driveable but had to be feathered around the track. Not fast at all. In a last ditch effort to redeem myself and the car, I installed the DIMEC20 +8 chassis. HOLY CRAP!! Finally, the car does what it's supposed to do. Turns great, jumps flat, easy to get on power. Knocked a second and a half off my hotlap and added 2 laps to my best run. I was able to hang with the fast guys and stay mostly on pace with them. Awesome. Setup is far from perfect, but at least I've got a good starting point now. If you're having the same issues with the car, spend the $30 and replace the chassis. Yesterday was the first day that I was happy with the car.
#8995
Stiltskint
What engine, pinion and springs you run on your dex210?
Maybe to low right hight?
Mike
Mike
#8996
U should post ur complete setup and see if we can help u get it dialed in. A lot of guys r running on indoor clay here and could help u. FYI the stock box setup is not for dirt it is for carpet, that is why iit was so bad.
#8997
#8999
anyone have pics of the dimec with older style bodies
