Durango DEX210 Thread >
Like Tree80Likes
Old 10-28-2012, 06:30 AM
  #8431
Originally Posted by R-E-A-P-E-R-
The new look of these 210 buggies is horrible. I'm not sure what is happening with TD but I'm not impressed. They went from having one of the sickest looking cars to the absolute dumbest.
Really dont understand why they didn't make the DIMEC chassis fit the old body, saves making moulds for a new body!
Chris-s is offline
Old 10-28-2012, 07:01 AM
  #8432
t8rtot's Avatar
Trader Rating: 14 (94%+)
Unlike Durango to comprise
t8rtot is offline
Old 10-28-2012, 10:14 AM
  #8433
Trader Rating: 27 (100%+)
Originally Posted by mihaelbencek
i hope there will be a new body from jc or proline for the long chassi soon. the new body looks like a transformer. no style :-(
I already sent the suggestion to Pro-Line earlier this week....
ehartman_49348 is offline
Old 10-28-2012, 10:27 AM
  #8434
** duplicate **
Old 10-28-2012, 10:37 AM
  #8435
P6
you know they will its one of the best buggys itll take a bit but im sure they are already working on something possibly waiting for the competition to release so they can make a few changes so they dont look to much alike lol
P6 is offline
Old 10-28-2012, 11:57 AM
  #8436
Default Thanks for help
Want to thank everyone for info helping me make a decision I p/u my 210 buggy can't wait to put together they sold me savox 1267 servo high voltage, good bad or something else should I use a low profile servo for mid motor setup don't want to buy 2 servos to change between rm & mm thoughts?
dolfns1 is offline
Old 10-28-2012, 12:08 PM
  #8437
R/C Tech Elite Member
Trader Rating: 520 (100%+)
I have a shorty servo in mine, but i dont think its absolutely necessary..I haven't run MM though, so I cant comment if its needed for that config..Take your time on the build, and use the online manual from Team Durango website, there were a few errors in the included manual. Also view the diff build page while you are there, it helped quite a bit if you have never built a 210 diff before..
flame56mx is offline
Old 10-28-2012, 12:18 PM
  #8438
mechanic77's Avatar
I've got a Savox 1257tg in mine running a full length battery and mid motor....no issues, but no room to move the battery front or back
mechanic77 is offline
Old 10-28-2012, 12:55 PM
  #8439
P6
i had the 1258 it worked great super fast , i now have the 1251 low profile its .1 sec slower 19oz-in less so i dont notice it but the size is noticable and 7g lighter than the 1258 add 7g under it you got lower cog and same weight , i actually drilled holes and can now move the battery stop up 10mm more . i have everything centerd in this order front to rear _servo shorty reciever esc rm3 motor , i have 15g under the servo 7g tightly fit in the front hinge pin holder and 15g more under the steering crank , the front feels planted and if i want the 7g reciever can move and ill have 140mm of battery space
P6 is offline
Old 10-28-2012, 02:02 PM
  #8440
onekiwi's Avatar
Originally Posted by Cspurlock
Randy,
When u say adjust shims, u mean the ones that run against the idler gears correct? If so, can u completely remove one of them? I was always afraid to for fear of the race binding on the case.
Appreciate your advice as always, and thanks again for the awesome support on the chassis.
THats not a bad idea if it works, then you might be able to tighten those housing screws a little more. Or replace the shims with 1/8 flywheel shims maybe?
I did once put those small black washers you get in the kit in between the two halves, not great as it leaves a gap but I could tighten it pretty good.
onekiwi is offline
Old 10-28-2012, 02:17 PM
  #8441
joelwhite's Avatar
Trader Rating: 62 (100%+)
Got to try the RTR 210 yesterday. Put some 4 hole pistons, fluid in the diff and race tires. Most of the setup was spot on. Put my radio in but everything else was rtr. It was very good. Im impressed. Drove like a proper race car!
joelwhite is offline
Old 10-28-2012, 02:24 PM
  #8442
Trader Rating: 79 (99%+)
Guys, whoever is on the east coast, and going to get hit by this storm, be safe. I live right on the water in CT. We are going to get pounded..
Raul Garcia is offline
Old 10-28-2012, 03:29 PM
  #8443
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
How are you liking the DEX210? I enjoy mine in Hutch. I have not tried the MM setup yet. You like it over the Rear Motor?
Jeff
Jeff Werner is offline
Old 10-29-2012, 12:08 AM
  #8444
mobb187az's Avatar
Just ordered a dex210 finally! What's a good setup for indoor, Med to high bite clay, medium length track with some tight corners
mobb187az is offline
Old 10-29-2012, 04:02 AM
  #8445
Trader Rating: 125 (100%+)
Hope you and your fam stay safe bro.
I posted mine a page back. Here is a link to the track layout I ran on to give you an idea.
http://www.youtube.com/watch?v=NgSQR...layer_embedded
kwiksi is offline
