Durango DEX210 Thread >
Like Tree80Likes
Old 09-11-2012, 09:10 AM
  #7666
Trader Rating: 19 (100%+)
Originally Posted by jackcarter3
Those Durango tapered pistons are a great find! Thanks for that link. They are less than half the price of the others as well!
Amain sells a really nice set of pistons drills that goes from 1.0 to 2.0 in .05 increments. The pin vise is a bit janky, but for $15 it's worth it just for the bits. Made by GMK Supply if I remember right.
Jonny5 is offline
Old 09-11-2012, 10:12 AM
  #7667
jackcarter3's Avatar
I have the racers edge set. They work ok.
jackcarter3 is offline
Old 09-11-2012, 11:55 AM
  #7668
Trader Rating: 16 (100%+)
I was worried about the ball studs popping off the buggy, but instead it was a lower shock eyelet on the rear shock that popped. The metal pivot ball stayed screwed into the arm, but the eyelet popped off. I was able to pop it back on with very little effort. The eyelet was not cracked or damaged as far as I could see.
Since it was so easy to pop it back on I was thinking of using Losi 22 lower shock eyelets and pivot balls. I used them on my b4.1 with no issues. Best around IMO.
zipperfoot is offline
Old 09-11-2012, 12:13 PM
  #7669
Trader Rating: 125 (100%+)
Never had that happen. Maybe use a washer on the end of the screw that mounts the shock eylet to the arm.
kwiksi is offline
Old 09-11-2012, 12:47 PM
  #7670
murky123's Avatar
I have had that happen last sunday for the first time in 10 months with one of my front shocks of the buggy
murky123 is offline
Old 09-11-2012, 12:50 PM
  #7671
Brollywood's Avatar
if anyone is curious i found that if you put 0.060 lexan sheet under the battery it really made the car stable with great traction and steering. with this a shorty pack in the middle of the chassis is much better than with it mounted far forward. gave the car a nice roll characteristic while maintaining a balance and stability.
Brollywood is offline
Old 09-11-2012, 01:03 PM
  #7672
Azagar's Avatar
Defentiely this, I've been using shims from my dex408, nice too since they add a bit of bling but with purpose.
Azagar is offline
Old 09-11-2012, 02:34 PM
  #7673
coaltrain's Avatar
Butters?
Can you post your 2wd setup you use at Kurts and CRCRC? I'm thinking about trying my hand at 1/10 buggy and need somewhere to start.
coaltrain is offline
Old 09-11-2012, 03:11 PM
  #7674
Brollywood's Avatar
yea its butters. just pm me your email. it wont let it upload for some reason
Old 09-11-2012, 03:28 PM
  #7675
rcman182006's Avatar
Trader Rating: 15 (100%+)
Hey! its Chuck, you helped me tweak my DEX (all pink body) a few months ago
Originally Posted by coaltrain
Butters?
pm sent
rcman182006 is offline
Old 09-11-2012, 03:43 PM
  #7676
Brollywood's Avatar
email sent guys.
yea i remember you charles. the car was great sunday at crcrc. dax madden actually bought one today after he drove mine lol
Old 09-11-2012, 05:38 PM
  #7677
Trader Rating: 38 (100%+)
Hey guys, running indoor carpet and I need more steering, on and off power. Tires aren't the issue. Currently running rear motor, could go to mid, but have plenty of steering with my RB5 rear motor. Is there anything easyish I can try to get some more steering? Sorry I'm a n00b to car setup.
vw addict is offline
Old 09-11-2012, 05:50 PM
  #7678
Trader Rating: 79 (99%+)
Pic of my car from friday.
Raul Garcia is offline
Old 09-11-2012, 05:52 PM
  #7679
Autocratic's Avatar
Trader Rating: 26 (100%+)
Uh...this is a joke, right?
Track looks a little wet. How are those Proline tires? Car looks good though. Is that the same body you had at Motorama when I met you?
Autocratic is offline
Old 09-11-2012, 06:01 PM
  #7680
Brollywood's Avatar
nope not a joke. its what i did. and it worked very well. is it a joke to run a shorty pack slammed up against the servo?
