Durango DEX210 Thread
#7653
#7654
Guys I had a brand new indoor red clay track just open in my area. I look foward to do some real testing this winter. I had a chance to run on it Friday night, and my 210 was pretty consistent, managed to finish 4th in 2wd mod. Lap time in the 14 sec range.
Has anyone played with more antiquat? Changing height of inner ball heights on the rear.?
#7656
This is something I have started testing recently too. With your typically 2mm rear roll center the rear has too little camber gain in my opinion. But I've started adjusting my spacers on the other ball stud first since I'm using the TD alloy hubs. Was using 3mm to match the stock height of the stock plastic hubs, but have since switched to 1mm and it has been working for me.
#7657
This is something I have started testing recently too. With your typical 2mm rear roll center the rear has too little camber gain in my opinion. But I've started adjusting my spacers on the other ball stud first since I'm using the TD alloy hubs. Was using 3mm to match the stock height of the stock plastic hubs, but have since switched to 1mm and it has been working for me. Just wondering if the angle of the camber link really matters in what direction it slants towards if that makes sense.
#7661
You want the distance between the arm and outer ball to be more than the inner, if anything. This will give you a little more initial grip and slightly better corner entry steering. A more aggressive angled link will also let you run slightly softer dampening, due to the link trying to "self center".
I've been wanting to get the TD rear hubs and also shave down the rear inner mount to give me some more rear traction, but not sure how that would affect the strength of the mounting.
#7664
For all those talking about taper pistons:
http://www3.towerhobbies.com/cgi-bin...&I=LXCMXA&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXCMXB&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXCMXC&P=ML
I have a bunch from Nick on Oople, but got them before these were available. No need to order overseas anymore.
