Durango DEX210 Thread
#7396
#7397
Do you guys grease the transmission gears? Black grease? Silicone lube? Maybe that red Mobil grease? Nothing???
Thanks,
SoCal
Thanks,
SoCal
#7398
#7399
Yes, it fits the B4.1, Kyosho, and Team C wheels. I used the new Team Durango steering knuckle, Team Kyosho front axle (one with the hex already on it), and the Kyosho axle shims. The Team Durango axles should be out soon and or are already out. I know my lhs has them on backorder. I asked Jorn what axles he uses and he had his custom made.. ha
Team Durango Steering Knuckle Set (2) [TDR330382]
Kyosho Steel Axle Shaft Set (RB5 WC) (2) [KYOUM569]
Team Durango 5x10x4mm Ball Bearing Set (4) [TDR601002]
#7401
#7402
Jeremy do you recall what size bearing you used for the axial? The Kyosho uses a 5x10x4mm in the RB5. I am trying to make a parts list for the mod. Below is what i have so far, but I am guessing on bearing size.
#7404
I also just received the new Tresrey rear hubs in the mail today. I'll be fitting them this weekend and Cush and I are hoping to get out for some racing on Sunday. Our local track is hosting the onroad Nationals this weekend so we have to find a place to go play... The hubs look very nice though, red and CF always does.
#7405
Thanks Guys
I built it w/ a small amount of the black grease as the manual suggests; just seems a bit "sticky". I'm guessing it will thin up w/ some use. Really hate to tear back into it
SoCal
SoCal
#7406
#7407
They r using both. Seems like it depends on the track as to which chassis is being used. From what I have heard, there isn't one chassis that everyone has landed on yet, they r still testing.
#7408
Hey I hav a question - not too sure if it's a stupid one but couldn't find anything in manual or searching this thread.. Where do you measure ride height from for the front? I can't get close to 24mm, more like 34mm unless I wind down the droop screws. Any help is appreciated.
#7409
Measure it right before the bend for the kick up. I actually got rid of the bumps stops on the plastic pivot. I use 2mm limiters in my front shocks. I had dirt stuck between the bump stop and droop screw so I said screw it.
Off to the races!
