Durango DEX210 Thread
#7321
#7322
[QUOTE=zipperfoot;11113128]Few questions before I make the purchase...
Does anyone know the final drive ratio so I can figure out my own gearing without having to bug you guys?
I plan on running a 13.5. What gearing works?
Found this funny since you went ahead and "bugged" us anyways about gearing.
Also, I am going to run at SRS which is an outdoor track, hard pack, and at a indoor clay/dirt track. Should I start with RM3 or RM4?
Billy fisher runs rm4 at srs and rm3 at tuscan.
His setups found here: http://www.petitrc.com/setup/durango...ngoDEX210.html
Finally, everyone seems to be running four hole pistons, in the range of 1.2, 1.3, and 1.4. Does anyone make pistons in this size or should I just drill out some blanks?
Ghea racing makes them for the car but they are 22 bucks on Amain.
I epoxied the stock ones to have 4 holls and have worked fine. I would recommend that unless you want to drop the 66 bucks or so to get all 3 types.
#7323
[QUOTE=nolimit208;11115717]
I just ordered two sets from Nick (4 x 1.3 and 4 x 1.4):
http://www.oople.com/forums/showthre...hlight=tapered
I believe they're coming from England, and run about $9.00 / pair. Have yet to receive them, but noticed other forum members have purchased from him w/ good results. I'll follow up when they arrive.
SoCal
SoCal
#7324
thats an error on the setup sheet... billy did NOT run RM4 at SRS.. ever.
#7326
#7327
i belive is same like AE so is 2.6
#7328
Losi will fit. i`m using those losi
#7329
So is it just me, or is there VERY LITTLE clearance between the rear axle and the diff screw nut Seems I have to crank down on the diff screw nearly all the way so the axle doesn't rub on the nut.
#7330
It's close, but if everything is built and broken in properly it doesn't rub, and is not too tight.
#7331
My first question about gearing and you consider that bugging you? Ok.... My apologies. I run several types of motors in my cars depending on what class i race. If i got on the forums and asked for gearing options every time i switched motors i would consider that "bugging you". Not cool. Thats why I asked for the final drive ratio.
Fyi I went back a couple thousand pages and read up on springs, gearing, motor layouts, etc. I used the search function, and came up with a bunch of information, some current, some old, some for mid motor, etc. some of the info given was just plain wrong. I thought my questions were relevant to current trends and conditions. thanks to those who helped.
Appreciate the info.
#7332
#7333
List of Spares to Buy at Initial Purchase
Hey Guys, after much research, I finally ordered my DX210 from my LHS (YAY!!!). I was choosing against the TLR22. I couldn't fathom the steering slop of that steering slider system that they got and didn't want to have to run saddle packs if I wanted to switch from rear to mid motor mounting.
Anyway, I wanted to compile a list of "easily breakable" parts to order ahead of time. Here is what I found so far. Can someone add/verify?
I found several occurrences of people needing
Rear Shock Tower #TD330342
Rear Inner Toe Blocks (part#?)
Ballcups #TD330293
I found some people stating these are needed as well, can people chime in? I don't want to purchase things unnecessarily:
Steering Plate? (part#?)
Front Shock Tower? #TD330342
A-arms? #TD330337, #TD330338
Castor blocks? (part#?)
Spindles? (part#?)
Thanks and I can't wait to build and drive it!
Can someone also confirm part numbers?
Ballcups #TD330293
Spindles? (part#?)
#7334
Ballcups #TD330293
Spindles? (part#?)
Ballcups #TD330293
Spindles? (part#?)
#7335
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
about to post my dex210 with 1 day on the dirt in the for sale section gents.few sets of tires, all the essential spares...
