Durango DEX210 Thread
#3632
26 is fine but with that 60c i might go higher to simply keep the tires from blowing up. The smaller the pinion the smaller your powerband. As weird as that may seem its easier to drive when the powerband is spread out. You can still drive if the tires are "hazing" in a slow spin. no way your going to overheat anythign with a 2wd so you basically gear to fit your traction and/or driving style. I tend to run big pinions which also help with braking.
#3633
I decided to join the DEX210 club. I have been running a DESC410 since it came out and I bought a DEX410R a few months ago and have been very happy with them. Build went together with no problems, fit and finish was great. So far I have run it twice at the local track. I have had no issues at all, took some good tumbles getting used to it and the ball cups stayed on. The ball diff is one of the smoothest I have run and easy to tune. Funny how things work out, I started many years ago with a 1/10 Tamiya Grasshopper buggy, moved on to nitro 1/8's, then more recently SC 2/4wd, and finally 1/10 buggies again.
#3638
You could always give the BugleBoy lid a try? He ships quickly. My undertray order took just a few days from Australia to Norway.
http://bugleboyracing.com/index.php?productid=12
-S-
-S-
#3639
I have finally even given up on my original non-HD ballcups. A popped ballcup took me out in the first corner of the first lap, in a really large regional race this last weekend. The guy behind me over jumped the first double at an angle, and landed directly on top of my car, and it popped a front camber link. 1 lap down right off the bat... Two days of practice, prep, and qualifying, just to lose due to somebody else popping one of my ball cups.... fed up.
Lunsford Ti studs and RPM cups coming in the mail.
#3640
whats the way to go on the battery for this car on indoor clay tracks? been running the shorties in the losi 22 and i liked the lighter feel. like the way this car looks on the track so i just picked up one. thanks
#3642
ok thanks thought it might make the car react,more nimble, like it did with the losi.
#3644
With the HD ones that come with the kit, if you got a batch that don't pop off at the drop of a hat, keep them and run them, they will probably work find. If you end up having popping issues like me and a lot of other people have, move to something better entirely.
#3645
I didn't run the HD ballcups long enough to know if they develop slop, because they popped off the car too easily. They are a DNF waiting to happen. So I moved to durango's original ballcups that are not their HD ones... they are better, but still pop off too easily for my liking.... the non-HD ones develop a lot of slop, but mainly in the rear.
......You and YOUR HD ballcups
They must have run two different batches of the HD ballcups because mine, in addition to not having any issues with them popping off, have very little slop for how many runs I have on them (60+) Soo weird....
