Durango DEX210 Thread >
Like Tree80Likes
Old 01-13-2012, 10:52 AM
  #3526
lockmouth's Avatar
Trader Rating: 33 (100%+)
Originally Posted by TonyWest
Those Associated o rings stretch around the top of the durango shocks. They are leaking from the top where they go together. No I don't think there are any burs on the shock caps. the o-rings are squishing out.
When the caps are installed on right the oring want squish out at all. I have my shock caps super tight an my orings don't stick out at all. Try install the cap again... it takes a couple tries to get them right sometimes.
lockmouth is offline
Old 01-13-2012, 10:58 AM
  #3527
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
I take a hobby knife and slightly bevel the inside edge. This pushes the ring inward and allows you to tighten them more.
Atomicsickness is offline
Old 01-13-2012, 11:03 AM
  #3528
Furtado66's Avatar
Put some shock oil on the o-ring then tighten it down. Had the same problem the first couple of times
Furtado66 is offline
Old 01-13-2012, 11:22 AM
  #3529
sparkwraps's Avatar
Trader Rating: 34 (100%+)
+1
Allows it slip on the cap. Without a light coat of oil, the cap will grab it and it will move it around. Tighten it up by hand and you should be good.
sparkwraps is offline
Old 01-13-2012, 11:57 AM
  #3530
RacerMike42's Avatar
Thumbs up
I had to do the exact same thing to keep the oring from squishing out
RacerMike42 is offline
  #3531
Autocratic's Avatar
I rebuilt my shocks with TL22 bladders last night instead of the TSR ones, for those running bladders, and they fit much better. No leaks, no shock rebound.
Also, rebuilt my SC10 gear diff with Mugen 10k oil. Feels a lot better on the bench than Losi 7k. Got my box of shims from A Main today as well. Currently running ten on each side, with the gear teeth backing cut out.
Racing tomorrow morning, so will be able to report on how I do with mid-motor finally in a race. As long as the track gets watered I think I should have a good chance of getting better traction than other buggies.
Also, picked up a Tekin RS because my Viper stopped working. Running it with my Trinity 6.5.
Autocratic is offline
Old 01-13-2012, 04:39 PM
  #3532
TonyWest's Avatar
Trader Rating: 50 (100%+)
thanks for all the help guys
TonyWest is offline
Old 01-13-2012, 04:57 PM
  #3533
Autocratic's Avatar
Honestly I think the shock cap o-rings are too small. I've been looking for some thicker ones.
Beveling the shock cap inside is a nice detail too. If I have more issues with my caps leaking I'll try that next. Although, mine haven't leaked since I first built them. I've just been having issues with the bladders leaking. Hopefully that issue is solved now with the TL22 bladders.
Old 01-13-2012, 04:58 PM
  #3534
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Have you used bladders before? I was thinking of trying them, but don't really need another area to do R&D..My shocks seem to want a refresh of oil a little more often than my "K" cars did..I am thinking its the cap orings letting some air in, as they dont feel real positively sealed.
Tekin and a 6.5 in a 2wd, you must be a heck of a driver to be able to hang on to that thing..
flame56mx is offline
Old 01-13-2012, 05:12 PM
  #3535
MantisWorx's Avatar
Trader Rating: 28 (97%+)
10k in the dif????? please get back to us on that!! i actually went as light as i possibly could and it feels much better than 2k in my yard track but tomorrow will be on an actual track wo we will see!! i am going to bring some 3 and 5k grease with me.
MantisWorx is offline
Old 01-13-2012, 05:34 PM
  #3536
Anyone looking for a rarest of rare--a 4mm low torque rotor, I have one..
Old 01-13-2012, 05:43 PM
  #3537
Autocratic's Avatar
I've used bladders before but it's been awhile. I was using the TSR bladders when I first built this buggy and they always seemed to leak. The TL22 ones seem to seal much better.
6.5 isn't as bad as you would think. I'm only running a little timing on the motor and that's it.
I ran two complete days at the track on 3k and 7k. Both were controllable but with how slick the track has been this week I was getting too much "diffing out".
Overall I'm happy with the setup I ended up with Thursday. I really want to raise the rear roll center more but I've taken out all the shims. I was thinking of cutting the transmission case tabs down like 1mm or 2mm and see how it works.
Marcus, you using anti-roll bars yet? The kit I ordered for the DESC410 will work but the fronts need to be bent, and the rears need to be cut. Also, need to find a longer full-threaded screw to use for the mini-ballcups.
Attachment 861754
Uh...free spin it at 100% or something? What rotor is that?
Old 01-13-2012, 06:40 PM
  #3538
The Juice's Avatar
Trader Rating: 25 (100%+)
Looking for some suggestions to fix my screw up. I made the holes to big on the wing for the body post and now theres some movement in the wing. Do I need a new wing or is there a trick I cant think of to fix it?
The Juice is offline
Old 01-13-2012, 06:49 PM
  #3539
nah, I was checking a speedo at about 50%, and it just locked..too many laps I guess..
Old 01-13-2012, 07:22 PM
  #3540
Autocratic's Avatar
Make a new set of holes.
Moving the wing away from the tower will give you more rear traction. Moving towards gives less.
