New Xerun 150a/80a esc-motor combo's
#1111
I assume it is possible to update the software via PC / internet? do i need a specific cable or can it be done via the programming card? Not sure which version i am looking at but want to make sure it's not going to give me issues.
also would the 4274 motor you recommended (for my buggy) be good for a 1/8 truggy as well?
#1112
Hey all, just about to pull the trigger on a new 150A combo but have heard that there is a brand new version out now.
The store i'm buying from says this is the latest model but how can i tell? Is there likely to be much difference? If its just software is and older version able to be updated via the net?
Another store is advertising theres as the newest release but is $30 more, which way to go??????
Need help asap
Need help asap
#1113
i believe their are only 2 versions and everything is the 2nd version now. i could be wrong though. i just picked up the ezrun sc8 120amp and sc2700kv 4pole motor from kershaw designs, their price was right their with everyone else and they are located near me.
#1114
Need help asap
Need help asap
I have contacted hobbywing china, there's no newer version xerun 1/8 esc except newer software only.
The only new esc they are testing is the sc8 sensored esc.
#1118
Hello a did a search of this thread and didn't find any refrence to a problem a fellow racer is having
Only sometimes when he plugs in a battery and switches the esc on the motor fires up for a few seconds full throttle then stops.
He has the transmitter on first.
Here is what he has Spectrum DS3 Hobbywing 80A ESC Speedpassion 2200kv Motor
Any Ideas
I have not sat down to troubleshoot just looking for ideas
Any Ideas
#1119
Any Ideas
Any Ideas
#1124
Does anybody use the 2000kv system in a Hyper 9E?
I've just bought the 150a/2000kv system and have found that the included pinion gears with the Hobbywing ESC are the wrong pitch for the 9E spur gear and the included Hyper 9E 14T pinion is too small causing the motor to hit the drive cup.
So what gearing do you guys use to get around this? Thinking about getting the novak pinion gears in perhaps 15/16/17T and using the smallest I can get away with.
Will be running on 4S batteries.
Cheers
Stricko
Cheers
Stricko
