New Xerun 150a/80a esc-motor combo's
#946
This will be my second post
Few days ago, I was finished my conversion of Hyper ST PRO with Xerun M3A on board . I use pretty slow gearing like 11/52 and 12/52 with 4S lipo. Everything is fine, but I worried about motor temp. With that gearing, after five minutes run, motor temp are 129-136 F. Outside temp was 57 F.
So, Is this normal, or I should try replace this motor to another in my rcshop?
Best Regards and Thanks.
#948
Few days ago, I was finished my conversion of Hyper ST PRO with Xerun M3A on board . I use pretty low gearing like 11/52 and 12/52 with 4S lipo. Everything is fine, but I worried about motor temp. With that gearing, after five minutes run, motor temp are 129-136 F. Outside temp was 57 F.
#950
its this one:
http://www.amainhobbies.com/product_...C-Carbon-Black
I think it only supports up to 3s
#951
its this one:
#957
#958
check the meshing & anything binding also. R u doing speed runs also?
I would suggest play in 10min segments. Let the motor n batt cool down.
#959
Hi,
Is the xerun 80A enough for 4wd SCT on 2s? I'll be using Novak 4.5T 550 motor on it.
Thanks.
Thanks.
