HPI Vorza Flux 1/8 E-Buggy Thread
#8222
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Nice one guys
any ideas if I can buy one over here - my soldering is shocking
where do the uk guys get your spares from? Thanks in advance
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
![EEK!](https://www.rctech.net/forum/classic_images/smilies/eek.gif)
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
#8223
#8224
Can anyone who owns a Turnigy 5S 40C lipo post the official weight of that battery if they have a scale? I want to compare it to my 6S 40C and my 2x2S 40C lipos...
#8225
Finished 4th @ CRC Raceway in Rome, NY with the Vorza
(Practically a D8 hopped up with Mods now).
So far this season --- 1st in A-main @ TBG locally & 4th in A-main @ CRC (which, was my first time running).
And guess what?
Not one breakage in 1.5 hours of practice, 2 qualifiers and the main.
Oh, and did I mention it was light rain all day?
This has by FAR been the best buggy I have owned to date.
By far.
Question: What are the opinions out there on the Trophy Truggy Flux? I haven't been hearing good stuff about it locally as the support apparently sucks, and the truck breaks a lot. Does anyone have any direct experience with it?
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
And guess what?
By far.
#8226
help, i just bought a savox brushless high tork steering servo and when i turn hard and suddenly let go of the wheel the ecu sort of turns of then on, can any one please help me!! this is super bad when you are doing high speeds because for a split second the car shuts down and could very well end up hitting a tree /wall ps that servo hurt my wallet...... whats wrong with it??
#8227
#8228
It has happend with me too.
Buy this and you won't have more issues:
http://www.amainhobbies.com/product_...iver-Capacitor
vlw
#8230
Hi, what's your opinions on the best battery to put in my vorza for bashing? Im confused as to the best c rating etc, turnigy would be ideal as I can get them from hobby kings European warehouse, has anyone used their "nano tech" battery's? I'm running a 21 pinion with a 46 spur
thanks for any help
#8231
There won't be a "best" battery, but there is an assortment of good batteries to use. For 4s, I use a TrakPower 4s 5600mah hardcase (that's also ROAR approved). This battery is kind of pricy at $160, but it came with my used Vorza. For 5s, I've ordered a Gensace softcase for $130 that I will have to solder deans connectors to. I'm not interested in running 6s, as the car already has a plethora of torque on 4s and 5s, so I just upped the gearing to 22/44. 4s is honestly enough for off-road bashing, so I plan to use the 5s for on-roading with my belted street radials.
In general, you should pick either 4s, 5s, or 6s, a mah rating not less than about 5000mah, and a "C" rating of no less than 30C. Also, using 2x3s or a 2s and 3s in series for a total of 5s or 6s will likely not fit without cutting the battery tray. A single 5s or 6s will fit (as long as you check the dimensions).
#8232
Appreciate the help Cobra
#8233
thanks for any help
#8234
My batteries have been getting pretty warm lately. Nearing the end of a pack they're at nearly 120 degrees farenheit. I'm running "nice" batteries, too... a 4s TrakPower 5600mah 50c and a 5s Gensace 5300mah 60-120C. I'm not getting puffing though, so I'm thinking that over the course of a pack (30 minutes) that the heat from the esc is saturating the battery leads, which then brings the heat to the battery. I'm also running 22/44 with a freshly tuned car, correct gear mesh, and the stock 2200kv. The hottest my motor and esc read is 150F.
#8235
Is there anywhere in the uk I can buy mugen parts?
