HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree16Likes
Old 10-19-2011, 01:05 PM
  #6511
Z4Kevo's Avatar
Originally Posted by Azagar
Anyone have experience with the HHH chassis? Looking to get one for my vorza over the Tekno one because I like the saddle pack configuration much more. My Vorza is practically a D8 Hara now with every single upgrade available done, the chassis is the final piece.
I hear it is a really good chassis from those that run it. The only issue many have had is getting one in a timely manner. From what I understand the guy who makes them does it on the side and it takes a while to get it delivered and it is really hard to get in touch with him to find out what is going on while you are waiting.
I went with the Tekno chassis since I had so many 4s packs and didn't want to switch horses. The balance of the tekno is very good...I love mine.
I don't think you can go wrong either way though...its just a personal preference on configuration.
Z4Kevo is offline
Old 10-19-2011, 01:20 PM
  #6512
TimMo846's Avatar
Originally Posted by timritchieblue
Toe in on the rear??? How do I adjust the rear toe in???
that I don't know.... lol I don't think you can...... you can adjust the cambering but not the toe. if your toe is off in the rear its not a adjustment setting you have to worry about. check the brace on the very back of the chassis.The rear pivot plate, i know on some there are multiple plates that come with it like a 3-2 or 3-3 pivot plate. The stock is a 3degree, a little expensive but maybe this one it's a 3.5 degree toe pivot plate http://www.amainhobbies.com/product_...e-Block-System
TimMo846 is offline
Old 10-19-2011, 01:22 PM
  #6513
Z4Kevo's Avatar
Yes. That is exactly what you would use.
Z4Kevo is offline
Old 10-20-2011, 03:28 AM
  #6514
jones8352's Avatar
Default advise needed
About a month ago the esc in my Vorza burst into flames. HPI sent me a new one, I set it up and all seemed fine. I ran it for about five mins and it quit running. It didn't get hot, every thing seems in order. When I turn the switch on it doesn't make the arming sounds and the yellow light comes on. The servo works but not the motor. I've tried different batteries and even put in a tx out of another buggy that I know for sure that it works. I double checked the motor wires and they're plugged in properly. Any body have any ideas I really don't want to send it back to HPI. Another thing when I first turn on the switch the fan doesn't come on. I checked it and it spins freely.
jones8352 is offline
Old 10-20-2011, 05:50 AM
  #6515
Z4Kevo's Avatar
Check the motor plugs again...on the ESC and the motor...sometimes they can get gummed up and it doesn't take that much (almost like a dark tarnishing on the gold plating) and prevent the ESC from detecting the motor and/or causing a short/stutter while running. I had this happen before and all I did was scrape away the buildup and it is good now. Not sure what caused it...neither was Castle. Something probably got in there and caused some kind of reaction under all that voltage...now I just keep an eye on them. Hasn't happened since. Hopefully that's all it is.
Z4Kevo is offline
Old 10-20-2011, 07:17 AM
  #6516
Hi guys, heres a vid from when i was playing in the sand the other week.
http://www.youtube.com/watch?v=h4wAX-1O5S8
Mods> removed wing, turned out well, as it landed shiny side up alot. F=R stainless bashplates, carbon chassis protector. i went to a fabric shop, and got some stuff similar to outerwears, and covered the esc, worked awesome, perfect even. doing wheelies blew the 2 front paddletyres, from the center diff action 'hyperspeeding' them, that sucked. also the badlands, and the paddles to some degree, filled up with sand from the air holes in the rim. stock vorza wheels dont have that, so i boiled off the paddles, hole punched two 3mm holes in each tread, and cloth taped the insides, 2 laps, befor gluing them to stock vorza v7 wheels. these tyres went awesome after that. i also hotglued the diff, to stop the overspeeding, but as it heated up from use it remelted. didnt really work out. then after it refroze. pretty annoying. Great day though Alot of fun and well worth hours in the sun being sandblasted.
Damage> 2 paddle tyres, front spindle carrier stripped, broke one steering tie rodend, curved both center driveshafts, busted up spotlight, 4 exploded BNIB badlands, cracked front off battery tray, loose front diff cup grub screw.
maxxaire is offline
Old 10-20-2011, 12:46 PM
  #6517
jones8352's Avatar
I took a look and the plugs from the motor look like new and the esc is new. Just for kicks I cleaned both with contact cleaner but it didn't do any thing. Hard to believe that a brand new esc is defective. I've had the worse luck with the esc's in my Vorza. This is my third one since I bought it new in April. I take good care of my rc's, I don't over gear and I use quality batteries. The one before this one literaly caught on fire!!! Thanks for the idea Kev, it was worth a try.
Old 10-20-2011, 01:44 PM
  #6518
Trader Rating: 21 (100%+)
It could be the switch on the esc, they go bad a lot.
Tintman is offline
Old 10-20-2011, 01:51 PM
  #6519
Z4Kevo's Avatar
Bummer man. I overlooked mine the first time and was was hoping it would be as easy as that for you too.
You getting power to the RX? If so, Do the lights on the ESC react to your trigger pull? ie. change colors? I've had mine intermittently forget its' calibration. Re-calibrated and everything was good.
Z4Kevo is offline
Old 10-20-2011, 03:32 PM
  #6520
timritchieblue's Avatar
Kool vid,, have you tryed paddles frt and rear?? Gettin ready to buy some. Post some pics of the esc cover
timritchieblue is offline
Old 10-20-2011, 07:40 PM
  #6521
jones8352's Avatar
I am getting power to the RX, I even put a new one in to see if that was it. The lights on the esc don't do any thing, as soon as the switch is turned on the yellow light comes on. I tried to re-calibrate it but it won't respond, it's acting like it's not seeing the signal from the tx. I know the tx is working because I use it on three other rigs and all work fine. In the am I'm going to put a new esc in. If it works then I'll know the Tork esc is defective.
Old 10-20-2011, 07:47 PM
  #6522
jones8352's Avatar
They do fail a lot but the lights on the esc come on and so do the lights on the rx so I know power is going through the switch. I wonder if it's possible that there's not enough power going through the switch to arm the esc, is that even possible. I guess I could cut it off to see, I don't really have any thing to lose.
Old 10-20-2011, 08:59 PM
  #6523
c0nr4d's Avatar
Jerry
Sorry bout your mishaps man... Hopefully HPI will help you out asap.
c0nr4d is offline
Old 10-20-2011, 09:52 PM
  #6524
ebailey95's Avatar
try plugging it in to castle link and reset the whole ESC just to makes sure.
is the lead to the RX plugged in correctly(not backwards)?
what happens when you dont have the rx connected and you turn it on?
Try unplugging the servo, sometimes a bad servo can wreck havoc on a system. I used to have a Summit where 1 of the 5 servos went out and it was screwing EVERYthing else up.
Just some suggestions. Hope it helps.
ebailey95 is offline
Old 10-21-2011, 12:49 AM
  #6525
Hi, yea i had 4 paddles at the start, but the fronts blew out, from wheelies. very frustrating considering how hard they are to find, and how $$$ they cost. where are you getting them from??
i recently bought a hyper7E, but love the vorza more, so bought a D8E, and a D8 Hara Tekno, and am waiting for them to arrive from overseas. so ill have 3 Vorzas soon. ill sell the hyper, and keep one type of parts.
ive already blown 3 motors in the one i have, for different reasons. wheres hte best spot for rebuilds? ive found them for $25 but when u order thay say mistake ectect, and now 55-65. any help? cheers guys.
maxxaire is offline
