HPI Vorza Flux 1/8 E-Buggy Thread
#571
Ah, you got blue in 76mm for your 112mm shocks?
I'm getting 60mm white for the front and 68mm yellow, 68mm red and 60mm blue for the rear.
#572
I think the Blue 60mm might be good too, cause they are inbetween the White and the Orange 60mm, but they end up being far down on the shock body because of the amount of preload you have to use to keep the ride height at a manageable level. The Stock Orange 60mm were pretty far down on the collars, and the Blues are softer, so that's why I went with the Red 68mm and Blue 76mm.
When I get a chance to test them I'll let you know how it turned out. I really want to keep 45wt oil though, because in the summer it'll only get worse and require heavier fluid. If I can't find a good combo using the springs mentioned above, I'll get a set of 1.2 pistions and start testing springs again with those.
- Paulie
#574
To be honest, you really don't need to upgrade the Vorza's servo at all. It's very good for what you get. I only got the Hi Tech because I'm using it in my D8, and I wanted the steering feel to be the same (The HiTech is slightly faster than the stock unit in the Vorza).
But for someone new to the hobby, the stock servo is plenty, and it's a good match for the Vorza. I'd rather put that money into a 2.4ghz radio first, if I were outlining an upgrade path, but that's just me.
- Paulie
- Paulie
#575
When April comes around I'll be running it every weekend so I'll have more feedback then.
#576
To desticker or not to desticker?
I have never been a fan of stock body stickers.Most of my cars were never rtr so I had to paint them myself.I looking at the vorza and am wondering if I should just leave them on.The blue isnt bad.But on the other hand a smooth silver and a black wing could be cool too.What did you guys do?
#577
I for one am getting the D8 body and painting it in my color scheme.
I spoke to HPI / HB and they showed me how to mod the body so it fits on the Vorza.
Once I get it I’ll be posting step by step instructions on this thread.
#578
Anyone have any good tire suggestions for onroad ?. I was using my aka cityblocks in hard compound and in just one session 50% of the tire has wore off !.
#580
#581
I use the Road Rage tires on my E-Maxx and they hardly show wear. Of course, the extra hook up also means I have to be careful on the throttle if I don't want to flip it under power.
ben
ben
#582
Wow... a lot of great info on this thread, thanks everyone!
Can anyone tell me detailed differences between 2200kv & 2650kv?
Would there be any true benefits in changing out to the 2650kv?
If so what are they and what pinion gear would be best?
#583
Hey Vision... what is that digital meter you got hooked up to the battery?
#584
Also, i was going to ask you what kind of speeds are you getting with the smaller spur gear?
#585
I made my own decals on waterslide paper, then layed them on top of durable flouescent vinyl. Simple, but effective - and definitley not RTR looking.
- Paulie
