Team Associated 1/8 Electric Buggy Info and Tips
#796
My center diff also leaks bad in my truggy.
#797
G'day Guys,
While we're talking about weight loss, I've lost 200lbs on this magic new diet.... Nah, I want to turn my fat old 3.7+ kg biggy into a sveldte, trim 3.2 kg buggy.
Have any of you fellas tried putting your rc8Be on a diet?
Mines pretty much stock apart from ft cnc knuckles, but I'm thinking of using all of the lightweight drivetrain parts (might save 50 or 60 grams, but it's rotating mass) a lundsford screw kit (at about $300 aud delivered that gunna hurt) and the GHEA worlds kit. I'd love to try a carbon chassis, but at it's current weight I'd be worried about it's longevity.
Has anyone else got some ideas on light weight parts that are available?
Smokey
Smokey
I saw that price on the screws the other day...there has got to be another/cheaper screw kit!??? too rich for my blood! Anyone know of a cheaper kit/solution?
I'm about to order the lighter drivetrain parts myself.
#798
fasteners-express.com for alum. screws. and you can order mugen ti screws they are cheaper than lundsford. also racers edge sells some items. I use some alum nuts. also on the bottom of the chassis i use alum screws that hold the f/r diffs and radio&battery tray. jmo
#803
for those of you running the 8 x 1.3 pistons, what oil do you suggest? 40f/35r? anything under 35 seems to be extremely soft on the bench -although real track conditions will exhibit a different "set" fluid dynamics within the shock on the track vs on the bench -its hard to tell.
#806
good luck i posted about a week back on it own thread and got no answers. I just wanted to know whihc lipo balancer wire to tap on the 4s to run the bec
#807
I've got the Tekno V4 chassis on my RC8 and am looking for some batteries. I don't plan on racing, but would like the option. Ideally I'd be running the Gens Ace 4s 40c batteries, 5000mah, except I can't get my hands on them. With that said, I have a couple questions:
I'm running a Castle 1800kv motor with a mamba Max Pro ESC. 17t pinion and stock spur (converted from nitro, not sure the tooth count).
For bashing, how concerned do I have to be about my "C" rating? Will a 4s 20-30c battery be fine, or will it be asking for too much out of the pack?
Mah: Currently I mess around with a 20C 3s, 4000mah battery. I don't run it hard because the battery will get warm, puff and all that good stuff, so I can't really judge what kind of run time I'd get. If running a similar setup, what kind of run times are you getting out of how many mah's? Or, do I NEED a 5000mah to be happy? I'd be happy with 15 min run times.
#809
#810
gearing for rc8be
looking all through this entire tread ive noticed lots of 1800 kv and 2200 kv being used how much effect is a for example 1800 kv geared with a 46/19 running cool in out of state temps in the 70s, here in south texas 100+ in summer gonna effect the motor . should i look to buy some other motor or sacrafice top end to keep temps cool . kinda lost here thanks or if someone down here in the south has a set up they would like to share . again thanks
