Team Associated 1/8 Electric Buggy Info and Tips
#646
I also agree that you should get castle. Why don't you want it? IMO they are the most reliable system out there now. I don't know much about LRP and your second choice is Tekin. I still read that their esc's are failing but the motor's run great.
#647
What are the run times on a castle 2200kv system?
#649
Picked up a set of the new aluminum rear hubs. My question is the mounting of the camber links in the hubs. It comes with the 2 cone washers with each hub but no instructions. Do the washers go inside the hub on either side of the link or on the outside and the link floats on the screw.
#650
#651
#652
#653
your welcome! If your looking into motor's and esc's, depending on if you bash or race. I would either go with castle or tekin for motor's and castle only for esc's. Then a lower KV motor paired with a higher cell battery for longer run times and lower temps.
#655
http://204.186.93.64/BrushlessMotorSystems.htm
So much to choose. Which one on an RC8e keeping in my I want long run times!!!
#656
I have a 2200 with 46/17, SMC 5200 and at one track I run on Fridays I finished a 15 min main with juce left to spair. It is a very techinical track. The other track I run on Sundays is allot more open with more straights and higher speeds I hit cutoff at 14.40 min in the 15 min. That was frustrating but I wasnt the only one that happend to.
#659
http://www.weather.com/outlook/recre...USMO0975?role=
