SC10 Thread
Old 04-30-2012 | 10:45 AM
  #11596
I have been running the STRC hex adaptors for almost a year with no problems, no bearing issues, held in place with a set screw. $10 a pair from Amain
LeftyAEguy is offline
Old 04-30-2012 | 10:50 AM
  #11597
question about the proline protrack beadlock wheels.
I have the jconcepts aluminum 12mm hexes on the rear, and some axial 12mm aluminum hexes on the front, will I be able to run the proline protrack beadlock wheels on my sc10 and still have them be the right offset? proline doesnt list the actual offset anywhere, im trying to find out if they will sill fit under the body.
getloose is offline
Old 04-30-2012 | 01:55 PM
  #11598
bds81175's Avatar
Moderator
You got a link for those? I don't see anything there but stuff for Traxxas.
bds81175 is offline
Old 04-30-2012 | 04:00 PM
  #11599
FORT-26's Avatar
i'm getting ready to search thread, but does anyone have a quick parts list for b44 rear hub upgrade? I just smoked my rear inner bearings, and was gonna upgrade tonight...
FORT-26 is offline
Old 04-30-2012 | 04:28 PM
  #11600
FORT-26's Avatar
GOT IT!
But I was reading that the bearing most common to failure was the outer one.....]
I blew out both inner bearings after about 20 min. of runtime after installing the rear JC hex adapters...
I'm hoping the B44 hub/bearing upgrade will fix this problem!?!??!
FORT-26 is offline
Old 04-30-2012 | 04:36 PM
  #11601
Acill's Avatar
Ok, so after some testing now with the normal arms back on these shocks are even hotter!! I'm still looking for a fix for the front to bring my ride height down a tad bit. The truck is running amazing now as is though.
Oh and I just ordered the Avid clamping hex set. For the price I don't think they can be beat. $17 for all four of them.
Acill is offline
Old 04-30-2012 | 05:07 PM
  #11602
19_mustang_96's Avatar
Originally Posted by jstump
i absolutely hate the v2 shocks no matter what i do i cannot get them to no leak, looks like these proline shocks are the way to go.
I had the issue with V1 Shocks. have you ever used AE green slime?
19_mustang_96 is offline
Old 04-30-2012 | 07:09 PM
  #11603
Default ST Racing Hexes
http://www.amainhobbies.com/product_...ter-Set-Blue-2
Old 04-30-2012 | 07:33 PM
  #11604
Get the white spacers from AE shock rebuild 6440 and use Kyosho X-rings with green slime. Should not leak anymore.
Brian L is offline
Old 04-30-2012 | 08:32 PM
  #11605
ae-Dan's Avatar
I understand that the o rings are probably better but why the white spacers?
ae-Dan is offline
Old 04-30-2012 | 08:35 PM
  #11606
weavty1's Avatar
Probably so that the shocks aren't allowed to 'bottom-out' or reach max compression/bound, which would cause over-pressuring within the shock body, leaving you more susceptible to leakage.
weavty1 is offline
Old 04-30-2012 | 08:39 PM
  #11607
t0p_sh0tta's Avatar
I'm pretty sure he's referring to the spacer that goes between the 2 o-rings.
It doesn't affect compression/rebound.
t0p_sh0tta is offline
Old 04-30-2012 | 08:43 PM
  #11608
tom_chang79's Avatar
Has anyone successfully applied a J82 kit to the SC10? I'm thinking about converting my SC10 into a J82 but I realize that the SC10's chassis has a longer wheelbase?
tom_chang79 is offline
Old 04-30-2012 | 08:55 PM
  #11609
weavty1's Avatar
Whoopsie
weavty1 is offline
Old 04-30-2012 | 09:02 PM
  #11610
elex300's Avatar
So I always set up my shocks with 0 rebound. But it never fails the Monday after a race weekend I check over everything and the shocks have anywhere from 1/4 to 1/2 rebound. I used green slime when I built them. This happens on both my SC10 and the B4.1 v2 shocks. Is this normal? Should I bleed them before every race to maintain 0 rebound?
elex300 is offline
