SC10 Thread
Old 03-23-2012 | 04:05 PM
  #10846
CraigMBA's Avatar
Avid enters the big bore spring fray. Users will have lots and lots of choices to confuse themselves with here shortly!
From here:
http://www.liverc.com/photos/albums/...actus_Classic/
CraigMBA is offline
Old 03-23-2012 | 04:34 PM
  #10847
has anyone used aka enduro on a dry dusty track? how did they go?
Hotbodiesd4 is offline
Old 03-23-2012 | 07:05 PM
  #10848
AlanHall's Avatar
Originally Posted by cschroedersc10
yes, it does it on both sides, but the front is perfectly fine, and yes it with the shocks completely off.
Its tough to say man. if you've taken the steps to make sure everything firs and is assembled correctly.
AlanHall is offline
Old 03-23-2012 | 07:55 PM
  #10849
BlueGlowBoy's Avatar
worked great as rears on the drier days at my track, though even the dry, dusty days, it was pretty hardpacked.....they use something like a cement roller after watering the track, so the WORST it gets, is still pretty firm....
BlueGlowBoy is offline
Old 03-23-2012 | 08:12 PM
  #10850
goose ae's Avatar
Anybody using the rear sway bar kit. I was going to try it but wanted some info.
goose ae is offline
Old 03-24-2012 | 06:34 AM
  #10851
Tried the sway bar, couldn't figure it out, ditched it.
I hear they're ok on carpet.
justinmahn is offline
Old 03-24-2012 | 08:50 AM
  #10852
Jokermayhem's Avatar
Default Avid Aluminum Bellcrank help please....
I should be getting mine very soon in the mail and was wondering what possible shimming I might have to do that some people have talked about during installation...feedback please...
Jokermayhem is offline
Old 03-24-2012 | 08:59 AM
  #10853
BorackBasher's Avatar
no one at my local track (OCRC) uses sway bars on their 2wd sc10. i couldnt imagine what they would do to the truck?
BorackBasher is offline
Old 03-24-2012 | 09:48 AM
  #10854
The Captain's Avatar
I run a rear sway bar, helps keep the rear end squared up on high traction tracks. With the sway bar, cornering is a tad more precise. I would suggest removing it in bumpy track conditions.y
The Captain is offline
Old 03-24-2012 | 02:58 PM
  #10855
goose ae's Avatar
Thanks for the info guys.
goose ae is offline
Old 03-24-2012 | 03:00 PM
  #10856
goose ae's Avatar
Mine fit perfectly. The only thing I've seen is its a tight fit in the rs trucks.
goose ae is offline
Old 03-24-2012 | 03:13 PM
  #10857
outlaw07's Avatar
Hi all can any 1 hekp me ,,i install a lrp shere tc spec esc in my stock sc10....with the stock reedy 3300kv motor ......now because they(motor wires) were all together coming out the motor i just matched the colors ,,with the exeception of blue and black turned on the power and the motor began to stink then smoke ...so i unplug the battery,,,i can get another stock reedy motor but will it happen again ? I new to this elec world ......does any one have any suggestion
outlaw07 is offline
Old 03-24-2012 | 03:21 PM
  #10858
elex300's Avatar
You most likely did some damage. Just because the wire colors match does'nt mean thay are the same. You need to look at your manuals for both the esc and motor you are using and see which color is A,B,and C and match up that way,not by color. All companies are different. You can try to hook it back up after doing this and you may get lucky.
elex300 is offline
Old 03-24-2012 | 08:49 PM
  #10859
Suspended
Wow your post was very hard to read. In addition to being new to the electric r/c world are you new to speaking English? Proper grammar, spelling and punctuation go a long way for getting your question answered. I think that the older LRP ESC's automatically went into brushed motor mode if the sensor wire is not hooked up. I could be thinking of another ESC being that I have never run an LRP brushless ESC, but I am fairly certain I remember hearing older LRP's doing that. If this is the case, the Reedy 3300 is sensorless, this is most likely what happened. It may have done damage to the ESC in addition to your motor. Best bet is to use a sensored motor with a sensored ESC, and a sensorless motor with a sensorless ESC, or something like the Tekin or Castle MMP that can do both. It really is that easy.
h8thatadmin is offline
Old 03-24-2012 | 09:17 PM
  #10860
Hey guys. im running on a hard packed dusty clay track here. http://nrccc.wordpress.com/track-pictures/ ( thats wet) do you think i should run a sway bar on the rear? i am stumped. it keeps spining out and cant drive in a straight line. please help =)
