SC10 Thread
#9346
only kidding ik how u feel about this lol! I wanna run my sc10 now tho..
every body seems to be doing well with the team setup..
#9349
I got that GPM blue servo saver setup that basically does the same thing from what i can tell as the Avid rack, albeit probably not as nice looking.. Came in today and it also has the alloy ackerman bar (correct term?) as well. I may try it first without that part as that would give it alittle flex.
#9350
The E clip is used to give the bearing thrust in the front. You need to put that in, but you also will likely need more parts because you've likely either roached a bearing or wasted the knuckle. So congratulations, you now have all of the problems anyone ever had with the proline setup, PLUS you are 2mm narrower!
Seriously, put the e clip in.
This is mine. It measures .350" from the edge of the hub carrier to the edge of the hex. Note how little of the axle remains between the hex and the taper.
In the rear I just pulled the big blue spacer. Left the small shims. And installed the deeper of the 4 plastic hexs in the AE hex kit. This is with JC wheels. I have aka and the newer JC I haven't tried yet. I got the wheel set used. So possible its thinner fir a different truck? I just used the big cone washer I took off the hub as a washer on the outside. Its only like 1mm difference causing the issue.
#9351
As fir the back.. we are exactly the same.. I must be thin on the rim..
#9353
http://www.reflexracing.net/RSD-12mm...m-_p_1063.html
But even without them, I can chuck up every hex rim I have.
#9356
the gluing the servo saver is to do the same thing as the aftermarket stuff, eliminate flex in that area. By eliminating the flex, you get more direct steering. f you take your SC10 with the stock setup throw your steering around lock to lock while it is still. Now, driving your vehicle around and at speed do the same thing. You will notice how you don't have the same amount of steering as you did before. thats because of the flex.
#9357
Getting a used SC10 today. No experience with this truck. I also dont know what model it is. I know it has the rtr brushless set up in it. Ive been reading and sounds like there are all kinds of rear drive variations as far as axles, pin drives, hexes, crush tubes, etc. nightmare already!! What has been found to be the best, easiest option for that? Basically club level racing so I dont need any extravagant set up. Also, how can I determine what model I have?
#9359
Basically if in your listing it looks like the front wheels have bearings in them, then you have the bearing / pin setup.
If your listing said it was a SC10RS, it should have the hex setup.
The hex setup makes it easier to line up the wheels on the rear, and you can also rotate your tires to call 4 corners getting better tread life as usually the rears where faster.
One *benefit* of the older setup is that you can probably find used and new wheels and front carriers slightly cheaper. At least, thats what I saw when I was pricing things up.
I personally had no issues with the pin / bearing setup. But, as I wanted the benefits of being able to rotate my tires in the future, I went with the hex setup.
